Dormer Windows - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2008, 12:32 PM   #1
Dormer windows
can anyone please show me some drawings for a small dormer window construction thank you
mj@mljackson.co.uk is offline   Reply With Quote
Old 06-22-2008, 08:09 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
please be more specific. you could use a wide verity of windows,
Are you referring to dog dormers that project windows from a roof?
Old 06-22-2008, 08:34 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Dormers are a type of construction (structure) that projects outward from a sloped roof. It's your choice of what kind of window(s) you wish to install in such a structural element.
Generally, the window is a standard designed double hung window, in terms of "window type".
- Build Well -
Old 06-22-2008, 08:43 PM   #4
As far as framing a dormer goes...I would not suggest that a novice DIYer attempt to perform such a project without some sort of onsite experienced supervision. This involves structural framing and structural support during the work process. You will need to obtain a building permit which will require a diagram showing how the dormer(s) will be structurally built.
Needless to say, here are examples of Dormer "framing". These are examples of two kinds of dormers, shed-dormer and gable-roof dormer.
Shed Dormer construction:
http://www.repair-home.com/how_to/add_a_dormer.htm
Gable Roof Dormer construction:
http://www.rd.com/17535/article17535.html
- Build Well -
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Dormer Help Gkalka Building & Construction 2 03-31-2008 09:21 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
