-   -   doorway (http://www.diychatroom.com/f14/doorway-122365/)
net_tech 11-04-2011 03:29 PM
doorway
I am looking to get doorway done as shown in the picture.
https://lh3.googleusercontent.com/-f...2r8/s576/2.JPG
Is there a way to get a break down of what material I would need for this project?
thanks
packer_rich 11-04-2011 05:05 PM
yes there is
sixeightten 11-04-2011 05:17 PM
You will have a tough time building that if you can't even figure out the material.
net_tech 11-04-2011 10:02 PM
doorway
a friend of mine works at the lumber yard, the carpenter I use buys everything from HD.
That's why I want to get the material myself.
Any help is appreciated
Kader516 11-05-2011 06:49 AM
Doorway
Not sure if anyone helped or not but without knowing the dimensions of the doorway it is hard to give you a material list. My guess. Is that you are going to cut the material yourself. You will need 3/4 mdf unless you want to use birch. The mdf will create your boxes, top cap, center medallion and base molding. Crown molding for the top. Chair rail for the middle trim and base cap or picture molding (can't tell from the picture), to use as the trim price. Be sure all the trim prices match the ones already used in the house. To create the arch pick up a sheet of 1/4" material to bend.
oh'mike 11-05-2011 07:34 AM
Make a drawing to scale---
Take off the numbers from that---Be sure you get the longest lengths of trim available to avoid waste.
There will be waste---you don't want joint in a long run---
Avoid the temptation to buy exactly what you need----I trimmed a room once where the customer supplied the crown molding----The job was like a puzzle--he had purchased the trim cut for each wall
what a time wasting night mare---I always try to supply the materials so this one irritated me.
woodworkbykirk 11-05-2011 07:57 AM
2 Attachment(s)
get your carpenter to do the material take off. if hes good with trim work it should take him about 5 or 10 minutes to figure out exactly what and how much trim he needs.
one thing to note though, this sort of trim detail is better done by a seasoned finish carpenter, tight joints and correct proportion are key with this sort of thing to be done right. ive seen many columns, and mantels that look like crap because the proportions weren't right
heres one of my columns
woodworkbykirk 11-05-2011 08:03 AM
yah, i know that situation mike.. but not via homeowner. through a really really cheap general contractor. we'd be trimming a 2000 sq ft house with a high end trim package.. hed bring enough molding to last me 3 hrs and think it would last 2 days.. along with a 1000 pack of gun nails.. another job were hanging 35 sheets of drywall hed buy a 500 pack of drywall screws
he didnt belive in using an account at the building supply either, i'd have to go buy more material or fasteners then chase him for 3 weeks to get the money back. needless to say i had some words with him and that was the last time i set foot on one of his jobs.. much happier now and i can afford to put gas in my vehicle again
net_tech 11-07-2011 02:16 PM
Width: 82
Height: 81
It's 8 thick
Height is gonna be an issue if I make it arch like on the picture above, so I am thinking of a straight run with a keystone in the middle.
net_tech 12-02-2011 04:39 PM
Figured some of the items out.
WM47 - 4 5/8" Crown
WM163 - Base Cap 11/16 x 1-3/8
WM956WW - 7/16 x 4 1/4 Backer
WM-300 - 1—1/16 x 3’ Chair Rail
WM-286 - 1-1/16 x 2 Rake
Can't figure out what the top is made out of.
tcleve4911 12-02-2011 04:50 PM
WM47 - 4 5/8" Crown
WM-300 - 11/16 x 3 Chair Rail
Top is crown with a 3/4" cap - probably 1x5 or 1x4
Like Kirk said, do a rough lineal footage ( not inch-age ) of each piece and round it up to the nearest foot and then add for waste.
These days you can over-order, keep the uncut lengths and return them to the yard for credit.
Willie T 12-02-2011 05:24 PM
If you still intend to buy the material for the carpenter, some of the best advice you can hear is not to. Let him get what he needs and what he feels comfortable working with. You getting in the middle of that process is not a good thing.
Ron6519 12-02-2011 06:47 PM
If your friend works for a lumberyard, why are you asking on the internet?
If he has a brain, he can identify the components in the photo.
