Doors For Wall To Ceiling Cupboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 10:32 AM   #1
JoelH's Avatar
Doors for Wall to Ceiling Cupboard
Hi,
I am building a wall cupboard - 22' wide by 11'6". For the bottom 8' high section I am putting in 5 sections of doors. The sections are 4',4',4',6',4'. I was planning on putting 2 regular hinged doors on each section but someone has suggested sliding doors which would need to be 4',4',4',3'+3',4'.
Section 1 would need to slide right, 2-left, 3-right, 4-1left, 1right, 5-left.
The upper cupboard will also need equal sized doors (but not as large) all across the top.
If we decide to go with the hanging doors we do not want to have problems with the sliders in the future.
What door options would you recommend and why? If you recommend the sliders what type of sliders do you recommend? Having sliders on the bottom is not an option.
I am building the doors not purchasing ready made.
Joel
JoelH is offline   Reply With Quote
Old 03-25-2011, 11:47 AM   #2
Rewards Points: 5,332
All the doors should be on hinges. Sliders cover 1/2 the space all the time.
Ron
Old 03-27-2011, 07:31 AM   #3
30 years in construction
canada94's Avatar
Send a message via Skype™ to canada94
I agree with Ron, hinge all the doors using concealed cabinet hinges
canada94 is offline   Reply With Quote
Tags
closet doors , cupboard doors , sliding doors
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 11:36 AM
3/8 Sheetrock joint at ceiling and at doors tuckerz Remodeling 3 10-11-2009 05:53 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
