Door With Wrong Holes For New Handlw - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-12-2006, 02:09 PM   #1
door with wrong holes for new handlw
I have an old exterior door with a spread of 3 1/2" for the handle and deadbolt. I want to install a new handle set that will have holes above and beneath the old holes. Any creative way to fill the old holes or cover them so I don't have to buy a new door?
Dave
davedla is offline   Reply With Quote
Old 06-12-2006, 03:00 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
Dave
Are the new holes too far away for backing plates? Maybe one small plate at each end will cover up the old?
J187 is offline   Reply With Quote
Old 06-12-2006, 11:17 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use epoxy wood filler. Look up 'Abatron' on the web. they sell several size containers that you:
mix, apply, sand smooth, and paint.....If you are going to stain, then leave a 'thickness' space and apply normal wood filler that you can stain.
- Build Well -
Old 06-13-2006, 01:11 PM   #4
Good idea, thanks.
Dave
Old 06-13-2006, 01:13 PM   #5
J187's Avatar
Rewards Points: 506
What kind of door is it? Is it a wood door?
Old 06-23-2006, 03:39 AM   #6
Dave
Hi Dave,
If the door is paint-grade finish, you should remove the old locks, and pack the hole with a dutch-man.
A dutch-man is wood that you use to fill-in the hole.
Last edited by Ron The Plumber; 07-07-2007 at 11:51 AM. Reason: Removed link, please get permissions from admin before posting link to your website.
rk_king2004 is offline   Reply With Quote
Old 06-23-2006, 11:01 AM   #7
Remodeler
MinConst's Avatar
There are also brass plates that will cover the whole area (no pun intended) then place your new lock set and it will look great.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-26-2006, 08:49 PM   #8
remodeling pro
If the door is painted you should cut a plug (best to use same type of wood as door, and orient the grain the same direction) and glue it in with a two part epoxy. I guess the new waterproof one part glues will work too, but epoxy is a forever deal. If the door is stained, you best hope is to search until you find a hardware set with trim plate that will entirely cover the old location, any kind of repair short of furniture quality will look like a sore thumb.
troubleseeker is offline   Reply With Quote
