Door Wont Latch - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-31-2014, 07:59 PM   #1
Rewards Points: 83
Door wont latch
My garage door keeps coming open. I thought the latch was old (it hasn't been replaced in 20 years) so I replaced it. It was still not latching properly..you can't hear a click when you close it. So I replaced the entire door knob and it still won't latch. The new knob can be adjusted to 2 3/4 or 2 3/8 but I measured it as 2 3/4 so I didn't adjust it. Any suggestions??
ttwin is offline   Reply With Quote
Old 07-31-2014, 08:11 PM   #2
Rewards Points: 12,914
Going to have to guess you mean the regular door not the over head door.
Close the door just enough to make contact with the latch plate, mark it with a pencil.
Now look to see if it's to high or to low.
Most often it's to low because someone did not use the included 3" screws in the hinges.
The longer screws would have been able to reach the studs behind the casing.
Old 07-31-2014, 08:14 PM   #3
Rewards Points: 83
Originally Posted by joecaption
Going to have to guess you mean the regular door not the over head door. Close the door just enough to make contact with the latch plate, mark it with a pencil. Now look to see if it's to high or to low. Most often it's to low because someone did not use the included 3" screws in the hinges. The longer screws would have been able to reach the studs behind the casing.
Thanks for advice. I I'll try that I adjust the latch to 2 3/8 and it way to long so that's not the issue. I should mark it what were? In the middle?
Old 07-31-2014, 08:29 PM   #4
At the top and bottom of the latch.
Then see how it lines up with the latch plate.
DO NOT JUST TRY AND MOVE THE LATCH PLATE UP OR DOWN !!
Old 07-31-2014, 08:36 PM   #5
Rewards Points: 83
At the top and bottom of the latch. Then see how it lines up with the latch plate. DO NOT JUST TRY AND MOVE THE LATCH PLATE UP OR DOWN !!
So I removed the latch strike plate before I saw ur response....sorry. The door closes perfectly now so I'm thinking it is an issue with the strike plate. Behind the plate there is another metal plate that makes it seem impossible to adjust the strike plate. So now I'm just lost.
Old 07-31-2014, 09:08 PM   #6
Go back and reread my post.
There's no need to adjust the latch plate.
There's no need to move the plate.
No need to remove the plate.
When that door was shipped there was a pack of 3" or 2-1/2" screws shipped with it.
There was missing screws in the top hinges and no hole was drilled.
Once the door was installed and plumbed someone was suppose to have drilled pilot holes and installed those long screws.
More often then not there left out or shorter screws where used.
Check the screws, if there loose the door will be off.
If there all 3/4" screws then the door can sag.
Got to tell us is the latch higher or lower then the hole in the latch plate?
Old 07-31-2014, 09:48 PM   #7
Rewards Points: 83
It's lower
Old 07-31-2014, 09:49 PM   #8
Rewards Points: 124
Grab some joint compound and smear it over the plate. Close the door ands throw the latch. Open said door and there will be marks showing exactly where everything is hitting. Ron
ront02769 is online now   Reply With Quote
Old 07-31-2014, 10:18 PM   #9
Pulled the top hinge screws out yet to see if there all short?
Any empty spots where there should have been a screw?
How low is it?
Sliding patio door handle latch busted dinosaur1 Windows and Doors 10 05-30-2014 10:08 AM
Latch on Sliding Door Budfudder Windows and Doors 2 09-11-2011 04:01 AM
Door latch / seal problem trswyo Building & Construction 4 08-19-2011 08:27 AM
door latch and lock doesn't close properly grgryl Windows and Doors 7 07-25-2011 10:56 PM
Window Sash Locks Won't Latch roztom Building & Construction 2 09-05-2008 06:44 PM
