Door Wont Close - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 08:34 PM   #1
door wont close
Ive got a door that hits the top of the door frame a little how do you get any adjustment. And the door on the bath room you push it closed it will swing back open by its self but it closes fine should i say latches fine . 2 different doors im talking about
cdundon4va is offline   Reply With Quote
Old 12-10-2009, 08:40 PM   #2
ArmchairDIY's Avatar
The one hitting the top of the frame: Try installing a long screw in the bottom hinge. This will pull the top down away from the frame.
The bath door that is hinge bound or has spring to it: loosen the hinges and slip thin cardboard (cereal box thickness) under the hinge closest to the hinge pin and re tighten the screws. This is trial and error you may have to ad more shims. The door is binding against the frame causing it to spring. You just need to find where and give it a little more room.
Good luck!
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 12-12-2009, 11:49 AM   #3
what he said plus get a belt sander and make sure the top and bottom of the door is painted to seal out moisture from warping the door
II Weeks is offline   Reply With Quote
Old 12-13-2009, 10:32 AM   #4
Pro
the one that hits the jamb. shave the top of the door down to clear the jamb and give you an equal reveal. problem is most likely caused by settling, and you frame is racked.
the one that has a spring to it. do what the other poster said with cardboard, granted you have enough space on the latch side of the door. if not, take old hinges off, and re-mortise them a tad deeper on the jamb side closest to the door stop.
ClemS is offline   Reply With Quote
Old 12-13-2009, 10:44 AM   #5
the one that swings open may just be hung out of plumb and may need no shimming
Old 12-13-2009, 10:49 AM   #6
Pro
i think we're all latching onto the keyword spring that the OP used. i gather he means there's a little bit of tension on the hinges as the door is pushed to close.
Old 12-13-2009, 12:15 PM   #7
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
If the door and jamb are painted, the paint may be hindering the door from closing correctly. Obviously if the door is stained this would not apply. I've seen many doors with paint build up on the face of the door, and edge of the door stop molding. I think a nickel, or is it a dime? should fit in that space for the door to operate correctly
A carbide scraper or block plane will remove paint build up followed with a light sanding.
Kevin
Kevin M. is offline   Reply With Quote
Old 12-13-2009, 01:53 PM   #8
Good point, I was making the assumption it was hinge bound and springing open it may very well be out of plumb and just swinging open on its own because of this.
Old 12-13-2009, 05:20 PM   #9
swing not spring
Old 12-13-2009, 05:22 PM   #10
Pro
swing not spring
sorry I re-read the OP and it does say swing. then it very well may be just an out of plumb jamb.
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 08:23 PM
Window won't close completely bucksone General DIY Discussions 3 06-25-2009 05:57 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
