Door And Window Trim, Touching - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 07:07 PM   #1
Door and window trim, touching
Ok I hate drywall work, as such will all of my projects involving windows I've tried to use window casing instead of a drywall return. I've got a door with windows on either side of it only about 4 inches away, this means that 2 pieces of 2 inch trim would basically be touching each other. In my head this seems like it would look weird, would it? I want to try to match the existing door casing in the house as much as possible, which is typical builders grade stuff, nothing fancy.
bigburb is offline   Reply With Quote
Old 01-05-2012, 07:37 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go for it, nothing wrong with that.
XXX
Old 01-05-2012, 07:40 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,348
first impression it sounds like a goof up on the framing,always frame for the finish meaning allow enough space for full trim to go up. in a situation like that i dont understand how there is only 4" of space. in a spot like that there should be a minimum of 5 -1/2" in between jamb extension as per proper framing methods.
if this is a retrofit situation thats different, heres where you have to get creative.. you can tweak the trim you plan on using by taking the stock trim and ripping it to 2" and butting it into one another and using a jack mitre technique at the header or you can do something custom to make it stand out a little more as its a entry way into the house via using custom milled mdf or pine
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
glkirk (01-06-2012)
Old 01-05-2012, 07:41 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Or you could go with a 1x6 instead of the two 1x3's next to each other, which is also fine. Your preference.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-05-2012, 08:56 PM   #5
hes not using 1x, clearly states using actual casing
Old 01-05-2012, 08:59 PM   #6
Disabled wood vet
titanoman's Avatar
Quack. Okay I'll put on my glasses.
Old 01-05-2012, 09:01 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OP: "I want to try to match the existing door casing in the house as much as possible,"
I don't understand the 1X6 comment.
XXX
Old 01-05-2012, 09:07 PM   #8
Missouri Bound's Avatar
Got a picture of your situation...maybe it will get our collective creative juices flowing....
Old 01-05-2012, 09:18 PM   #9
It is a goof in the framing by the previous owner, but I have to deal with it.
I'm a little lost on this, can you explain a little more? Thanks.
Old 01-05-2012, 09:23 PM   #10
Pictures...
Door and window trim, touching-img_20120105_211645.jpg   Door and window trim, touching-img_20120105_211733.jpg
Old 01-05-2012, 09:30 PM   #11
Ther's a lot of options.....and I'll bet the rest of the room is already trimmed...right? I would trim the windows like the rest of the room, just change the trim on the doors to "be creative" Nothing says you can't frame the doors differently to give it a custom look. Worse come to worse you can always rip a bit off the window and door to give you a bit of spacing. I just might use a 1 X 6 around the door and butt the top window trim(s) against it. Again it's a "custom" thing. Just because it's not conventional doesn't mean it's wrong.
Old 01-05-2012, 09:31 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just put the casing back to back and call it done. There is nothing else to do with that that will match the rest of the house. If the windows were at the same elevation as the door there would be one other possibility but that isn't the case so refer to Post #2.
XXX
Old 01-06-2012, 08:35 AM   #13
Rewards Points: 2,212
Yep back to back for quick, or make the door and both windows look like a unit with some "custom" trim. I like the idea of custom trim making the windows on each side flanking the double doors look like one unit.
With the windows lower you can still make it look good by bringing the tops of the windows across, mitre to o\go up then go across the top of the door. the pieces across the tops could be thicker stock so the vertical casing just butt into it
mae-ling is offline   Reply With Quote
Old 01-06-2012, 03:44 PM   #14
bud is on the right track with what i meant. you have to do the casing back to back but rip it down so both peices will fit to have the correct reveal.. the jack mitre technique is more advanced and not too many guys do it. i use this method and several other not too commonly used techiques for trim which make things really pop. however i have spent a good portion of my career handling 90% of the trim on the houses that my company renovates.. i run into all sorts of odd situations that require some creative tinkering to make it look right
look up gary katz- jack mitre you should be able to get a step by step on how to do it
Old 01-06-2012, 05:25 PM   #15
I wonder how that was built? Is there a header spanning all the windows and door? Why are the windows lower than the door? I would want those questions answered before I wirried about trim.
glkirk is offline   Reply With Quote
The Following User Says Thank You to glkirk For This Useful Post:
woodworkbykirk (01-07-2012)
