Door Trim Too Short - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 09:28 PM   #1
Door Trim Too Short
Had hardware floors put in. Now the trim around all doors is too short. Quarter round was put down but not along bottom of trim. Trim is not straight, has a bit of design to it. What can I do to fill the gap between the trim and floor which is almost 1/2"? Would caulk work? Thought maybe a piece of quarter round would work?
Ddunk42 is offline   Reply With Quote
Old 03-01-2012, 09:51 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
maybe a plinth block will work?
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
DrHicks (03-03-2012), woodworkbykirk (03-02-2012)
Old 03-01-2012, 10:06 PM   #3
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
im no pro and Im sure a few of them will chime in with how its done, but if im understanding you, there is a gap between the door casing and your floors. If thats the case , I think its called a Plinth block, either removing the vertical peices of trim and cutting them to allow this block to fit between the trim and floor, or maybe cutting in place with a flush cut saw(available at the box stores) using a guide block the same size as the plinth block. Check back on this post, ive been a member of this site a long time and these people here know they're trade and are always willing to help, They probibly know a better or more efficient way to handle it, good luck with it
jpc is offline   Reply With Quote
Old 03-01-2012, 10:07 PM   #4
jpc
jc
Rewards Points: 162
+ 1 To Tom, I read his post and was typing and after hitting submit i was thinking a picture would be better, then there it is.
Old 03-02-2012, 08:16 AM   #5
Green Hat
Rewards Points: 170
Thats my vote.
Mills314 is offline   Reply With Quote
Old 03-02-2012, 09:27 AM   #6
Rewards Points: 77
+1. Plinth or rosette depending on your taste as I've seen rosettes used on the bottoms as well. Your local hardware store should have a large variety of styles.
dengle is offline   Reply With Quote
Old 03-02-2012, 09:52 AM   #7
Rewards Points: 14,294
Agree a picture is needed.
Are you saying a real flooring company put the floor in?
If so then there's no excuse the casing or jams were cut off that high, (unless they were already cut that high before they installed the flooring.)
They could have been cut off exactly the heigth needed with a jamb saw, hand saw, ossilating saw and there would have been no gaps.
Is it just the casing that's to high or were the jambs also cut?
Old 03-02-2012, 08:59 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
installing plinth blocks is the best answer.. you can try to cut slivers of casing that will fit into the gap but it can look like crap.... caulking just looks worse
using an oscilating tool is the best method.. they have a much thinner blade than a back saw and it cuts quicker
woodworkbykirk is online now   Reply With Quote
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 08:38 AM
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
Furnace short cycling repman55 HVAC 12 01-21-2011 04:41 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 12:54 PM
