Door Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 05:01 PM   #1
Rewards Points: 252
Door trim
Hello everyone,
I was about to put up some door trim in my basement and I was looking at the current trim from the upstairs and I noticed the trim wasn't flush with the door jam. The trim was set back about an 1/8. This was for the sides and top. Is it normally set back an eighth? I never checked the detail of door trim until now.
I am sure this is a matter of preference but I would like to do it to standard, to whichever that is.
jburchill is offline   Reply With Quote
Old 04-07-2013, 05:40 PM   #2
kwikfishron's Avatar
Rewards Points: 582
3/8" has always been the standard in my neck of the woods.
kwikfishron is online now   Reply With Quote
Old 04-07-2013, 06:00 PM   #3
Rewards Points: 512
1/8-3/16 reveal here. i make up a plywood block and go around and mark all the jambs so they are all exactly the same. there is no real standard every guy does it a bit different.
princelake is offline   Reply With Quote
Old 04-07-2013, 06:16 PM   #4
Rewards Points: 636
1/8 to 1/4 inch matter of opinion
unless you have a rosette or plinth block some times they will dictate reveal
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-07-2013, 06:44 PM   #5
Rewards Points: 252
Thanks for the replies, I didn't measure the reveal. I could tell in the door jam, there was a different look to the door jam which was about a 1/4
Thanks again!
Old 04-07-2013, 07:58 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
if its the casing itself i go with 3/16 for thinner profiled casing if its thick casing i make the reveal 1/4" so that the casing doenst cause the hinge to rub and restrict movement.
woodworkbykirk is online now   Reply With Quote
Old 04-08-2013, 07:52 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
it helps to give a reveal on the door jamb with the trim to have a corner to caulk into. matching trim to the inner plane of the jamb leaves a tight line and as someone else mentioned the set back works to clear the hing pin on the hinge side of door...
hand drive is offline   Reply With Quote
Old 04-08-2013, 08:25 AM   #8
Rewards Points: 13,712
With a 3/16 revel there's plenty of wood in the jamb to attach the casing to.
Move it to far back and some are going to miss.
