Door Swinging Closed - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 10:22 AM   #1
Door swinging closed
We recently had some professionals come in to hang our new interior slab doors. We tried ourselves but failed miserably, partially due to the amount of sanding the doors need to fit in our old (1920's) door frames but mainly due to our lack of skills with the router, so we had a lot of difficulty mortising the hinges.
Anyway, the pro's came and did a great job, took their time and all the doors are great (except for one, which they cut too short, and are waiting for the new door to come in for them to replace). Aside from the door they're replacing, there's one that keeps swinging closed whenever it's opened. It's certainly not a violent swing, but it's enough to close it such that the cats can get trapped in the room, which makes them very angry.
Any way we can fix this?
P.S. It did this prior to paint and knob install, so it's not any kind of disproportionate weight thing.
jkrodger is offline   Reply With Quote
Old 04-08-2009, 11:39 AM   #2
Rewards Points: 176
Here's another thread on the same subject. I hope it helps.
Stop a door from drifting open?
gma2rjc is offline   Reply With Quote
Old 04-08-2009, 12:18 PM   #3
thanks!
Old 04-08-2009, 12:20 PM   #4
Rewards Points: 176
You're welcome. There are probably other threads as well that discuss the same problem with doors.
Old 04-08-2009, 10:46 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
Good recall, thanks for the trip down memory lane!
Man of many hats
wrangler is offline   Reply With Quote
Old 04-08-2009, 10:58 PM   #6
That's not a problem, that's a "feature" !!! (per MS)
They shoud have charged you extra for the auto-door closing installation
But that's OK, just send the $$ to me & I'll take care of it
I actually like this "feature" on my sunroom door
I'm always coming in during the winter with an arm full of wood
The door closes enough so that I can shut it with an elbow
Old 04-09-2009, 11:08 AM   #7
Newbie Bill
Rewards Points: 518
I think its ghosts.
drtbk4ever is offline   Reply With Quote
Carrier furnace giving r-w closed error? mel189 HVAC 7 11-27-2008 10:59 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Air Circulation w closed Doors CamL HVAC 8 02-23-2008 02:19 PM
Bathtub Drain partially closed??? Sellncars Plumbing 3 08-14-2006 01:43 PM
