Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-12-2012, 11:56 PM   #1
Door swing: right or left
Hello; I read a book where it says that if you look at the door and it swings
away from you and the hinges are on your right; then it is a right-swing door. Another video said that you look at the door and you see the hinges
protruding from the wall, then that side is the swing of the door. I bet you have more experience as to how to tell if a door is right-swing or left-swing.
Thanks.
Gaca2468 is offline   Reply With Quote
Old 06-13-2012, 12:03 AM   #2
STAFF
BigJim's Avatar
Place your back to the hinge, which ever way the door swings is the hand door it is, if it swings right it is a right if left it is a left.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following 8 Users Say Thank You to BigJim For This Useful Post:
gregzoll (06-13-2012), jaydevries (06-13-2012), kj6887 (06-13-2012), kwikfishron (06-13-2012), Missouri Bound (06-13-2012), oh'mike (06-13-2012), ratherbefishing (06-13-2012), Willie T (06-13-2012)
Old 06-13-2012, 01:39 AM   #3
^Tis tru and yet not that simple. Depends if it swings away from you or out towards you. Almost all Residential Doors swing in (away from you). And the above method works. Commercial doors and in rare cases Res. doors that swing toward you are the opposet. If you're looking at the door and you don't see the hinges (swings away from you) and the hinges are on the right. It's a right hand door (RH). If you can see the hinges (swings toward you) and the hinges are on the right it is a Right hand Reverse (RHR). The difference being called out for hardware. Say a linen closet that swings out. If you buy the opposet hardware the lockset screws would be on the outside.
Tham
Tham is offline   Reply With Quote
Old 06-13-2012, 08:16 AM   #4
See Post #2. This is the method that has been used since doors were invented. It makes it real simple too.
danpik is offline   Reply With Quote
Old 06-13-2012, 01:39 PM   #5
look at the hinge to have the swing side point to you...the side the knob goes on will tell you if right or left
terry603 is offline   Reply With Quote
Old 06-13-2012, 06:29 PM   #6
Framing Contractor
Post number 2 is the best way and easiest way and not confusing. We call it..."butt to butt"!
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-13-2012, 09:25 PM   #7
Stair builder
Most people use Jim's method but Tham is correct.
Keith Mathewson is offline   Reply With Quote
Old 06-13-2012, 09:47 PM   #8
Missouri Bound's Avatar
There are RH and LH doors....period. A RHR door is a left hand door that a lawyer was asked to describe.....
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
gregzoll (06-14-2012)
Old 06-13-2012, 11:30 PM   #9
^Ever install hardware? Panic bar? Anything?
Tham
Old 06-13-2012, 11:34 PM   #10
Tham
Yep...every bit of it. Lke I said, it's left or right, not reverse right means left and reverse left means right. And panic bars are installed on doors that swing out. Is this rocket science now? Now there are paddle alarm locks which can be used on in-swinging doors, but not panic bars. Panic bars have one use, shove it and run. It's all left and right.
Old 06-13-2012, 11:41 PM   #11
No not Rocket science. Just hardware.
Tham
Old 06-14-2012, 07:39 AM   #12
Haverhill Trade 1965
Right jiju. One old carpenter told me the best way to remember was, "butt, (yours), to butt, (the doors), and which ever hand opens the door." That has been the carpenters standard for the last 300 years or so in this country.
Duckweather is offline   Reply With Quote
Reverse door swing from left to right silverph Windows and Doors 9 04-20-2012 12:02 PM
Moving a socket from left and stud to right hand stud(and up 3 feet) raptor_demon Electrical 19 04-03-2012 11:27 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Change a door from left hand to right hand? mhaucke Building & Construction 10 10-08-2007 12:18 AM
thin film of oil on left front wheel bobo Automotive Repairs 15 04-11-2007 08:24 PM
