Door Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 08:30 AM   #1
door question
Hi,
Im building a playhouse for my son. The wall height is 6' so I need to come up with a way to fit a door in a small opening. The R.O. I have is 32x56. Any suggestions?
markharmon is offline   Reply With Quote
Old 07-02-2013, 10:28 AM   #2
Rewards Points: 13,300
Why the odd ball size?
Building it that way is going to just waste a lot of materials.
No lumber or plywood comes 6' long.
Old 07-02-2013, 10:44 AM   #3
Roofmaster
Rewards Points: 2,172
Build it out of tongue and groove material. Glue and screw a Z brace on the back. Make the Jambs of white pine, ripped to size. Just put a fence latch on the door so the kids cant lock themselves in................... Or you out
Old 07-02-2013, 01:39 PM   #4
What about for weather stripping and protecting, etc?
Old 07-02-2013, 03:26 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
you can buy door jamb kits that the top can be cut down to fit the door.
hand drive is offline   Reply With Quote
Old 07-02-2013, 03:38 PM   #6
is it difficult to install a slab door to the jamb though?
Old 07-02-2013, 03:51 PM   #7
kwikfishron's Avatar
Rewards Points: 186
Some can do it in there sleep...Others will pull there hair out trying and still not get it right.
kwikfishron is online now   Reply With Quote
Old 07-02-2013, 04:05 PM   #8
AHH, SPANS!!!
a miniature door is the same as a big door just smaller. you can also make your own jambs out of 1x material though if you have to go buy the 1x might as well get a jamb kit instead along with a threshold for under the door. if you can find a solid core door it should work for the door no matter how small the door is cut down. I've worked for eclectic people that wanted a door cut into the roof angle of a attic remodel with part of the door jamb embedded into the drywall for maximum clearance !
Old 07-02-2013, 06:33 PM   #9
Home Depot has a solid core luaun interior door prehung that I could cut down to fit. If I painted with an exterior paint do you think it would be ok for outside?
Old 07-02-2013, 06:43 PM   #10
Might work for a few weeks.
Make it 8" tall and all your problems go away, it can become a store shed when he grows up.
Could be built faster because there's so much less cutting.
Old 07-02-2013, 08:02 PM   #11
What do you suggest for a door for a 32x56 rough opening? Build a shed door from plywood?
Old 07-03-2013, 09:27 AM   #12
AHH, SPANS!!!
it will delaminate pretty quick from outdoor exposure but lots of builders use the solid core for storage buildings off the back of houses, I've changed many a solid core doors over time from de lam. a plywood door can be built too no problem...
