-   -   door question (http://www.diychatroom.com/f14/door-question-182907/)
markharmon 07-02-2013 07:30 AM
door question
Hi,
Im building a playhouse for my son. The wall height is 6' so I need to come up with a way to fit a door in a small opening. The R.O. I have is 32x56. Any suggestions?
joecaption 07-02-2013 09:28 AM
Why the odd ball size?
Building it that way is going to just waste a lot of materials.
No lumber or plywood comes 6' long.
jagans 07-02-2013 09:44 AM
Build it out of tongue and groove material. Glue and screw a Z brace on the back. Make the Jambs of white pine, ripped to size. Just put a fence latch on the door so the kids cant lock themselves in................... Or you out :laughing:
markharmon 07-02-2013 12:39 PM
What about for weather stripping and protecting, etc?
hand drive 07-02-2013 02:26 PM
you can buy door jamb kits that the top can be cut down to fit the door.
markharmon 07-02-2013 02:38 PM
is it difficult to install a slab door to the jamb though?
kwikfishron 07-02-2013 02:51 PM
199 Attachment(s)
Some can do it in there sleep...Others will pull there hair out trying and still not get it right. :huh:
hand drive 07-02-2013 03:05 PM
a miniature door is the same as a big door just smaller. you can also make your own jambs out of 1x material though if you have to go buy the 1x might as well get a jamb kit instead along with a threshold for under the door. if you can find a solid core door it should work for the door no matter how small the door is cut down. I've worked for eclectic people that wanted a door cut into the roof angle of a attic remodel with part of the door jamb embedded into the drywall for maximum clearance !
markharmon 07-02-2013 05:33 PM
Home Depot has a solid core luaun interior door prehung that I could cut down to fit. If I painted with an exterior paint do you think it would be ok for outside?
joecaption 07-02-2013 05:43 PM
Might work for a few weeks.
Make it 8" tall and all your problems go away, it can become a store shed when he grows up.
Could be built faster because there's so much less cutting.
markharmon 07-02-2013 07:02 PM
What do you suggest for a door for a 32x56 rough opening? Build a shed door from plywood?
hand drive 07-03-2013 08:27 AM
it will delaminate pretty quick from outdoor exposure but lots of builders use the solid core for storage buildings off the back of houses, I've changed many a solid core doors over time from de lam. a plywood door can be built too no problem...
