Door Pediment - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 11:41 AM   #1
Door pediment
How do you attach a urethane door pediment to the brick?
LRIDE is offline   Reply With Quote
Old 05-23-2013, 12:40 PM   #2
Haverhill Trade 1965
You could drive some finish nails in so the points are through, hold the pediment in place, tap the nails to make little marks on the brick. Remove the pediment hammer drill 1/4" holes where the marks are, cut some pressure treated wood like tapered dowels, (small end about 1/4") and drive them into the holes. Put the pediment back, drive the finish nails in, set and fill holes. You can add construction adhesive to the back too.
Duckweather is offline   Reply With Quote
Old 05-23-2013, 12:50 PM   #3
Rewards Points: 13,450
Most come with a trim ring that gets removed. Mark where the holes need to be and drill with a hammer drill, insterst Tap Con screws and reinstall the trim ring to cover the screws.
Old 05-23-2013, 12:54 PM   #4
Never saw that kind Joe. The one the builder I worked for were made by Fypon.
