-   -   Door pediment (http://www.diychatroom.com/f14/door-pediment-180241/)
LRIDE 05-22-2013 11:41 AM
Door pediment
How do you attach a urethane door pediment to the brick?
Duckweather 05-23-2013 12:40 PM
You could drive some finish nails in so the points are through, hold the pediment in place, tap the nails to make little marks on the brick. Remove the pediment hammer drill 1/4" holes where the marks are, cut some pressure treated wood like tapered dowels, (small end about 1/4") and drive them into the holes. Put the pediment back, drive the finish nails in, set and fill holes. You can add construction adhesive to the back too.
joecaption 05-23-2013 12:50 PM
Most come with a trim ring that gets removed. Mark where the holes need to be and drill with a hammer drill, insterst Tap Con screws and reinstall the trim ring to cover the screws.
Duckweather 05-23-2013 12:54 PM
Never saw that kind Joe. The one the builder I worked for were made by Fypon.
