Door Options For Wine Cabinet?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-19-2014, 02:43 PM   #1
Door options for wine cabinet??
Hello all,
I need help selecting doors for what will become a wine storage space under a set of stairs. It measures 37 inches across and the doors will be 55 inches high.
My general contractor, who is working on this as part of a larger project, suggests a standard 1 3/8" interior door cut down to make two doors. This idea troubles me because I think the door will look/feel too heavy, and, with the jam and hinges will be too bulky when opened.
The only alternative I've come up with, thinner, cabinet-type doors, would likely warp. So I'm looking for other options.
Any ideas?
Thanks!!
Door options for wine cabinet??-photo-1.jpg   Door options for wine cabinet??-photo-2.jpg
Inugami is offline   Reply With Quote
Old 07-19-2014, 03:04 PM   #2
Rewards Points: 6,652
What are you going to use, to keep the area at the proper humidity and temp? It does look a little on the small side, due to you will only be able to store on a shelf on the backside.
Most Wine & Scotch storage areas I have seen. Use Outdoor grade Steel or Fiberglass doors, with no windows.
Old 07-19-2014, 03:20 PM   #3
Hi Gregzoll -
Your comment about heat is spot-on; we don't want heat. This area is in a basement; the back wall in the picture will have a vent to a non-heated, unfinished area. That same area before being "improved" has been our wine storage area for 20 years with great results. The door will separate the cabinet from the heated room.
Old 07-20-2014, 01:10 AM   #4
Originally Posted by Inugami View Post
Hi Gregzoll -
Venting to a non-heated unfinished area is not wise. That space needs to either have a Wine Refer just put in there, or you will need a chiller unit, that keeps it at the proper humidity and temp.
You may want to talk to local wine shops about this, along with contractors who have done this kind of stuff. One thing you do not want in your setup. Is for the Wine to go bad, due to you did not think like Wine.
That unfinished, unheated area can easily become warm or have wide temperature swings that can easily kill your wine product in storage. Unless you are turning over a lot of wine every month, your idea would work. But not for the long term, or if you plan on stocking finer wines, etc..
Old 07-20-2014, 06:46 PM   #5
Rewards Points: 3,520
Since when do you store wine in a refer or a chiller long term????
Canarywood1 is offline   Reply With Quote
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
