Door Moulding Idea Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 12:11 AM   #1
Ok I have an smaller house with standard/boring door moulding and would like to replace it. The current moulding is 2 1/4 inch wide plain and outdated. I would like to replace it with something more modern and decorative but have a few problems...
1) I have an area where my bathroom door moulding meets a bedroom door's moulding and the seam is covered by quarter round. What can I do to make the juncture look better and fit in with a more decorative moulding? Would shrinking the bathroom door from 28 to 24 inches to accomodate a more decorative moulding be a bad idea? Any other ideas?
2) I have another bedroom where the moulding buts up against a wall. This doesnt give me room to go with a moulding that has decorative corners that are wider than the moulding.
Does anybody have some ideas how to fit a more modern decorative moulding into tight spots?
Thanks for your help.
Vibber is offline   Reply With Quote
Old 05-19-2010, 05:56 AM   #2
There are 2 1/4 or 2 1/2 colonial trim that are the usual choices to replace common ranch molding. Check local homes stores or lumber yards for samples of profiles.
Old 05-19-2010, 12:27 PM   #3
Jay123's Avatar
Can you post some pics? It usually helps.
Jay123 is offline   Reply With Quote
Old 05-28-2010, 08:52 PM   #4
Rewards Points: 150
When there is not enough space there isn't much you can do. Only rip the moulding to butt up against the adjacent ripped moulding. Do it nicely and the seam will not need to be covered. If it is an uneven rip just scribe it carefully. I always try to avoid 2-0 doors for a bath entry, 2-4 are much more user friendly and they look nicer. good luck.
TheCamper is offline   Reply With Quote
Old 06-01-2010, 07:51 AM   #5
So you have two 2 1/4" moulding that almost butt up against each other? Why not trim out the whole thing with 1x3 with a solid piece of 1x6 ripped to size to span the middle? Use some nice corner rosettes to finish the look.
gdoucette is offline   Reply With Quote
Tags
doors , moulding
feedback on business idea Jack000 General DIY Discussions 18 12-20-2009 08:01 AM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 07:45 PM
Is this a bad idea??? drillbit Building & Construction 3 08-19-2008 09:14 AM
Idea for kitchen peninsula acomiskey Remodeling 3 05-17-2008 02:12 PM
Carpet Idea...Will It Work? Topazprincess77 Flooring 1 03-19-2008 10:47 AM
