Door Knob Replacement - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 12:59 PM   #1
door knob replacement
I was going to replace the door kobs on all of my interior doors. However, the old door knobs do not have a face plate. The old latch simply inserts into a hole that is flush with the the door and has a metal ring around it to cover the rest of the hole. There is not much wood left around this hole, so I a reluctant to try to chisel it out. Has anyone ever seen door knob replacements for this configuration? I can email a picture if that would help. Thanks.
Last edited by firstmarvmark; 04-15-2013 at 01:25 PM. Reason: Adding photo of current hardware
firstmarvmark is offline   Reply With Quote
Old 04-15-2013, 01:04 PM   #2
Rewards Points: 528
Buy the regular door knobs and drill out the door for the new ones.
yes they sell replacements for existing, but the new ones last longer.
framer52 is offline   Reply With Quote
Old 04-15-2013, 01:18 PM   #3
Rewards Points: 13,300
Got a picture. May get some more suggestion if we can see what you have to work with.
Old 04-15-2013, 01:43 PM   #4
framer5,
If you have a web site that sells replacements for this type of configuration, can you please provide it? Thanks.
Old 04-15-2013, 01:57 PM   #5
Rewards Points: 528
Try this one
http://www.knobsandhardware.com/door...13.html?page=3
Old 04-15-2013, 02:02 PM   #6
Those latches just pop right out once the knobs removed.
Just put a screw driver through the hole where the knob was and pull on both ends of the driver toward the end of the door.
All the door knobs I've seen come with a metal ring to space that over sized hole to the new catch.
Just going to have to insert the new latch, hold it straight and use a pencil to mark out where the wood needs to be removed with a chisle.
Old 04-15-2013, 02:25 PM   #7
747
registered
747's Avatar
Rewards Points: 534
They still make those. My mom and pop lumber company has them. if you can't find one. Just a lite chisel.
747 is offline   Reply With Quote
Old 04-15-2013, 02:26 PM   #8
They all seem to have face plates that need to be embedded in the door (thus the need to chisel). I was trying to avoid that and just replace with the same type of latch shown in photo. I can't find a replacement that looks like that anywhere.
Old 04-15-2013, 07:07 PM   #9
chitownken's Avatar
Rewards Points: 510
They sell these at Home Depot and Lowes. Both Kwikset and Schlage. They have the face plate in the package but the instructions explain how to pop off the faceplate and add the round trim ring.
chitownken is offline   Reply With Quote
The Following 2 Users Say Thank You to chitownken For This Useful Post:
firstmarvmark (04-15-2013), oh'mike (04-21-2013)
Old 04-16-2013, 11:04 AM   #10
firehawkmph's Avatar
Rewards Points: 1,826
+1,
and the round ring will be in the package. I know I've thrown a ton of them away.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-17-2013, 12:05 AM   #11
Should be able to get the same latch set up these days but I wouldn't worry about chiseling it out for the new ones either.
jessrj is offline   Reply With Quote
Old 04-18-2013, 09:59 PM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
Yeah. That's a Kwikset privacy lock with a round-drive latchbolt. Still make them to fit that same hole.
Old 04-21-2013, 05:08 PM   #13
Rewards Points: 196
Dont they still make locks that have the ring plate seperate and if you wanted that installed as well you just slide the lock through it?
Jason34 is offline   Reply With Quote
Old 04-21-2013, 08:37 PM   #14
See above post #9
Mike Hawkins
Sash Replacement vs. Insert Window Replacement dcd22 Windows and Doors 15 07-27-2014 05:39 PM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
replace replacement windows theone Windows and Doors 3 10-19-2011 10:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
