-   -   door knob replacement (http://www.diychatroom.com/f14/door-knob-replacement-177214/)
firstmarvmark 04-15-2013 11:59 AM
1 Attachment(s)
I was going to replace the door kobs on all of my interior doors. However, the old door knobs do not have a face plate. The old latch simply inserts into a hole that is flush with the the door and has a metal ring around it to cover the rest of the hole. There is not much wood left around this hole, so I a reluctant to try to chisel it out. Has anyone ever seen door knob replacements for this configuration? I can email a picture if that would help. Thanks.
framer52 04-15-2013 12:04 PM
Buy the regular door knobs and drill out the door for the new ones.
yes they sell replacements for existing, but the new ones last longer.
joecaption 04-15-2013 12:18 PM
Got a picture. May get some more suggestion if we can see what you have to work with.
firstmarvmark 04-15-2013 12:43 PM
framer5,
If you have a web site that sells replacements for this type of configuration, can you please provide it? Thanks.
framer52 04-15-2013 12:57 PM
Try this one
http://www.knobsandhardware.com/door...13.html?page=3
joecaption 04-15-2013 01:02 PM
Those latches just pop right out once the knobs removed.
Just put a screw driver through the hole where the knob was and pull on both ends of the driver toward the end of the door.
All the door knobs I've seen come with a metal ring to space that over sized hole to the new catch.
Just going to have to insert the new latch, hold it straight and use a pencil to mark out where the wood needs to be removed with a chisle.
747 04-15-2013 01:25 PM
They still make those. My mom and pop lumber company has them. if you can't find one. Just a lite chisel.
firstmarvmark 04-15-2013 01:26 PM
They all seem to have face plates that need to be embedded in the door (thus the need to chisel). I was trying to avoid that and just replace with the same type of latch shown in photo. I can't find a replacement that looks like that anywhere.
chitownken 04-15-2013 06:07 PM
They sell these at Home Depot and Lowes. Both Kwikset and Schlage. They have the face plate in the package but the instructions explain how to pop off the faceplate and add the round trim ring.
firehawkmph 04-16-2013 10:04 AM
+1,
and the round ring will be in the package. I know I've thrown a ton of them away.
Mike Hawkins:)
jessrj 04-16-2013 11:05 PM
Should be able to get the same latch set up these days but I wouldn't worry about chiseling it out for the new ones either.
Maintenance 6 04-18-2013 08:59 PM
Yeah. That's a Kwikset privacy lock with a round-drive latchbolt. Still make them to fit that same hole.
Jason34 04-21-2013 04:08 PM
Dont they still make locks that have the ring plate seperate and if you wanted that installed as well you just slide the lock through it?
firehawkmph 04-21-2013 07:37 PM
See above post #9
Mike Hawkins:)
