Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-10-2009, 05:24 PM   #1
Default Door knob hole size discrepancy
I want to replace 35 year old Weslock interior door knobs with new ones from Schlage. The holes in the doors (Masonite/composite type, 6 panel) are exactly 2" in diameter. The Schlage template on their website calls for a 2 1/8" hole.
Will these Schlage locks fit 2" holes as well? Or am I stuck with trying to enlarge the holes by 1/8"?
Thanks.
janralix is offline   Reply With Quote
Old 07-10-2009, 06:25 PM   #2
Yoyizit's Avatar
Originally Posted by janralix View Post
Or am I stuck with trying to enlarge the holes by [1/16"]?
Two ways that come to mind.
Grind the hole larger with a rasp or abrasive drill-powered metal drum.
Put a wooden dowel into the latch hole. This provides a center for a 2-1/8" hole saw. Once the larger hole is started you don't need the centering dowel. For only 1/16" this might not work.
Old 07-10-2009, 11:16 PM   #3
In some cases a perfectly round hole is unnecessary. It may be possible to form a somewhat oval hole to allow the guide pins to be inserted.
Old 07-13-2009, 03:50 PM   #4
Household Handyman
Wildie is probably correct for the DIY on this one. I ran into this so often I finally made up a plug to fit the 2" sized holes very tightly so I could center my hole saw to drill out to a new size depending on the lock-set size. I understand most DIY's don't have all this to work with. Hold one-half of the new Schlage unit up to the existing hole to see if all of the internal parts will fit into the 2" hole with possibly the exception of the guide pins. If it appears that all the internal working parts will fit then you may only need to enlarge the hole on each side for the guide pins to fit. You will only need a good hand operated wood rasp to do this. Good Luck, David
Old 07-13-2009, 04:24 PM   #5
General Contractor
I run into this every now and then and have found the easiest thing to do is drop a smaller hole saw measuring the diameter of the existing hole into a larger hole saw that is the desired diameter. The smaller hole saw then acts as a guide for the larger hole saw.
ARI001 is offline   Reply With Quote
Old 07-14-2009, 08:42 AM   #6
gravity always wins
Clamp a piece of 1/2 plywood to the door, flush on the edge on the high side of the bevel. This is the side of the door opposite the stop. Lay the template from the new lock on the plywood and mark the center of the 2-1/8" bore. (Should be 2-3/8" from the edge of the door and plywood). Make sure it's at the same height and centered with the latch bore in the edge of the door. Drill through the plywood and the door with the new size holesaw. When you are half way through the door, clamp a fresh piece of plywood on the opposite side of the door and finish drilling. Otherwise, you'll splinter the face of the door when the holesaw breaks through. Yes, you'll need a 2-1/8" bore for a Schlage lockset. Yes, it is one of the better quality locksets out there.
Old 07-14-2009, 08:53 AM   #7
Man of many hats
wrangler's Avatar
I've done something similar to what M6 describes. I have a piece of 3/4" plywood already drilled with a 2 1/8" hole set for the 2 3/8" backset required for most locks. I also clamp it to the door, drill halfway through, then switch it to the other side and finish the hole.
Man of many hats
wrangler is offline   Reply With Quote
Old 07-14-2009, 09:05 AM   #8
I've found that Schlage locksets are very picky about being bang on with the hole size and cause alot of grief. I've found that Weiser locks are much more forgiving and allow more room for error.
If you're set on Schlage, I would use the method mentioned above - place a 2 1/8" holesaw over a 2" one and use it as a guide.
n0c7 is offline   Reply With Quote
Old 07-31-2009, 01:24 AM   #9
Thanks.
Hi,
I suppose you have to enlarge the hole for replacing your old interior door knob.
Keep Sharing and Reading, Have a nice time a head!
ADVERTISING LINK REMOVED
Lisa Wilson is offline   Reply With Quote
Old 08-04-2009, 10:11 PM   #10
i usually just run the laminate trimmer around the hole.....rarely do you need the exact size for the machanism ...just for the trim ring....
ropers is offline   Reply With Quote
More On This Topic
How to Cut Plywood
How to Cut Plywood by eHow.com
Plywood is a versatile wood product used extensively in shelving and cabinet construction because it resists warping and shrinking. Made from many layers of very thin wood pressed together in alternating directions, plywood easily withstands fluctuations... Read More »
Hi, I'm Jon on behalf of Expert Village. In this video clip we'll be making and attaching our trim on the top. On the edge of our table top we have our exposed plywood which doesn't look very good. So what we are going to do is make a piece of trim to... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be showing you how to attach our trim pieces. To attach my trim pieces I'm first going to glue each edge and clamp it to my board. The next thing I'm going to do is put a couple of pin... Read More »
Hi, I'm Jon on behalf of Expert Village in this video clip we'll be gluing up our legs. First I'm going to clamp one of my oak boards in place, just to show you what this is going to look like we are going to put our plywood pieces in next, and other oak... Read More »
Alright, what we're going to do now is we're going to clean out the inside of the barrel. We have all of our parts here scrubbed up. We have the Break Free setting in. We have a brush loose with the brushes. We're going to take our Hoppy's #9 and I... Read More »
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 24 05-30-2009 12:54 AM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 11:26 AM
Wire size and breaker discrepancy Randell Tarin Electrical 23 04-10-2008 09:03 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 12:28 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 09:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
