Door Jamb Replacement? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-17-2008, 08:09 PM   #1
Hello Forum,
I want to keep the existing door that's in great shape and only replace the door jamb, not so good of shape.
The house was built in the 80's with 2x4 construction. Is this a difficult task to do? Any tips or advice is greatly appreciated.
Thanks..
BostonMike3 is offline   Reply With Quote
Old 11-17-2008, 10:51 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you should be able to replace it.
Here's a link with a discussion relative to the subject. There are pictures too. The key is going to be: Patience, and having the right tools.
Hopefully this information can be of help to you:
http://www.hammerzone.com/archives/d...t/break-in.htm
- Build Well -
Old 11-18-2008, 06:14 PM   #3
Thanks for the site link, Atlantic.
But that's not what I had in mind. I'm planning on removing the existing door from the door jamb, that is in good shape. Remove all trim, interior and exterior and remove the door frame.
Rebuild door frame to exact measurements of existing, hinges, hardware, etc.. Then re-install back to original specs...
Just curious on level of difficulty? How long would something like that take? Any tips?
Thanks..
Edit: This is an exterior door and I plan on re using the threshold.
Old 11-18-2008, 06:56 PM   #4
How difficult such a project is, would be based on your personal skill level, and the arsonal of tools that you have.
You need the correct tools (table saw, compound saw, sharp chisels, drill, etc)
Generally the best method for this type of a project, would be to fabricate the new door frame with the jambs in a wood shop. Then it is brought out to the site, and installed.
If you don't have the tools suitable for this work, and feel that you lack the skill, you could take precise measurements and bring them to a wood shop, to have the new frame made up, and go for the installation and door switch yourself.
- Build Well -
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
replacement windows in stucco houser Building & Construction 3 08-23-2007 12:28 AM
replacement compressor needed for old GE rotolock alex977 HVAC 1 05-17-2007 08:36 PM
Soffits/Fascia replacement - I need some pointers! mcan5276@bellsouth.net Carpentry 1 03-13-2007 11:18 AM
