Door Installation Help Needed, Please? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2014, 03:37 PM   #16
Rewards Points: 13,960
Still have not answered why it's even there in the first place.
Is this a single story home?
The picture looks like it's a basement.
Where's the outside picture?
Where's the insulation in the ceiling?
Old 07-31-2014, 03:58 PM   #17
Aesthetics, there's no damage.
Cabling is above the ceiling panels.
It's a Tri-level.
Unicornz0 is offline   Reply With Quote
Old 07-31-2014, 04:16 PM   #18
Rewards Points: 42
Originally Posted by Unicornz0
Typically, can the grid for the ceiling tile be raised & positioned above the taller door trim? Thanks Again, Uni
The grid can be moved but then you are creating a new project. You either raise the entire ceiling, or create a bump up in the door area, or have half the door trim covered by the ceiling.
Dan
djlandkpl is offline   Reply With Quote
Old 07-31-2014, 04:39 PM   #19
Please explain what the bump is.
Seems like it may be the best option for the ceiling.
Thanks Again,
Uni
Old 07-31-2014, 04:56 PM   #20
Rewards Points: 42
Thanks Again,
Uni
Assuming there's room above the current grid, you would take a section and raise the grid. It would be higher than the rest of the ceiling but it would allow the door trim to fit properly.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
Unicornz0 (07-31-2014)
Old 07-31-2014, 05:02 PM   #21
Rewards Points: 42
I tried to find a picture online. This is an extreme example of the left section being higher than the rest.
Dan
Old 07-31-2014, 10:48 PM   #22
Rewards Points: 37
Screen doors on our house, that there was no way to do it. It took me around two hours and I had the new storm doors hung properly.*but properly way to use it.
garykerr is offline   Reply With Quote
Old 08-01-2014, 04:22 AM   #23
Please tell me where insulation should be added?
How will an exterior picture help?
Thanks In Advance,
Uni
Old 08-01-2014, 11:01 AM   #24
Roofmaster
Rewards Points: 2,210
Thanks In Advance,
Uni
The people here are trying to determine exactly what the conditions are. As Joe said it looks like a basement with a very low ceiling height where a dropped ceiling was installed. We cant see a header, and we cant see the threshold. You do not have a standard situation, so without more input, it is hard to help you. Why not take all kinds of pictures and post them? Its not like you are wasting film, or like it is hard to post pictures, right?
Old 08-01-2014, 11:16 AM   #25
Right!
Based on what's been written in this thread, I'll probably go with the "cut down" door, since it will fit better with the trim above the door.
Any tips on the ceiling insulation will also be appreciated.
Thanks Again Everyone,
Uni
Old 08-01-2014, 01:09 PM   #26
Rewards Points: 867
when you said fiberglass, i assumed exterior. is this an interior door install? and yes, that horizontal 2x board can likely be removed to add more height for your rough opening.
TimPa is online now   Reply With Quote
The Following User Says Thank You to TimPa For This Useful Post:
Unicornz0 (08-01-2014)
Old 08-01-2014, 02:12 PM   #27
Yes it's an exterior door.
Old 08-03-2014, 03:14 PM   #28
Rewards Points: 1,910
Sounds like a bait and switch scammer to me. They advertsise a 32x80 door at a sale price and then make excuses why you need an expensive special order. Did they measure your rough opening to make that determination? Tell us what they report your R.O. to be please.
Also ask the scammer what R.O. is needed for the $400 sale door and tell us that too.
Old 08-04-2014, 06:27 PM   #29
That's what I initially thought too.
Some here replied the new door height will be too tall for the existing dropped ceiling grid.
Two companies measured the vertical rough opening. The big box store said I need a "cut down" door, since the RO required for the vertical is 81.75".
Seems my vertical RO as pictured above is 81.25-81.50", without adjusting the block above the header.
The big box store said they will not adjust the block above the header.
The mom & pop store said they can make the standard door fit.
Can the door slab be replaced & a new weather stripping system added, keeping the original brickmold?
Thanks Everyone,
Uni
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Replacing rooftop deck - permit needed? esk8mw Building & Construction 5 01-27-2012 02:02 AM
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 07:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 01:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 07:56 AM
