Door Hinge Questions - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 02:09 PM   #1
Hi All
I'm a novice when it comes to DIY so please bear with me.
I have a sticking door. It's sticking at the top.
It's obvious that the door is not sitting square in the frame but I'm unsure of the best way to rectify this.
I have noticed that there is quite a bit of play in the top hinge. By this I mean that when I lift on the handle side of the door then I can see the play in the hinge.
My questions are:
1. Is it normal to have a lot of play in the hinge? (my thinking is that if there was no play in the hinge then the top of the door would be higher and probably wouldn't stick)
2. If it is normal then what is the best way to go about fixing the door?
Thanks in advance
Dave
DaveF is offline   Reply With Quote
Old 08-19-2009, 02:23 PM   #2
General Contractor
Try replacing the center screw of the hinges with #8 2 1/2" screw. That should correct the problem. If not post back.
Don't forget to tighten the other hinge screws if they are lose after you do this.
ARI001 is offline   Reply With Quote
Old 08-19-2009, 03:00 PM   #3
Rubber Floor Mat Guy
Screws
When you say loose hinge I assume you mean the hinges aren't tight to the door frame. If the screws are loose you can remove the door with the hinges and fill the screw holes with toothpicks and carpenter glue. Wait for it to dry, cut off excess toothpicks and glue, and screw the door back on.
bbdunleavy is offline   Reply With Quote
Old 08-19-2009, 04:07 PM   #4
The screws that hold the hinge to the door frame and the door are all tight.
The play is in the hinge itself.
I was wondering how much play is normal. It seems like a tight hinge would fix the problem.
Old 08-19-2009, 06:27 PM   #5
Old School
Willie T's Avatar
None.
Willie T
Old 08-19-2009, 06:59 PM   #6
Originally Posted by Willie T View Post
None.
OK...so I replaced the hinges and the door is better but it still sticks.
I put some shims behind the bottom hinge and it still sticks.
I think my options are:
1. Take off the top hinge and chisel out some more space there
or
2. Take the door off and sand down where it's rubbing.
What's the best way to go?
Dave
Old 08-21-2009, 03:20 PM   #7
or
Dave
Take the door off and plane it down!
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
When to sand and other questions... PaintedSurface Painting 4 03-27-2009 09:13 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
