Door Hinge Pin Trick - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 07:04 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
door hinge pin trick
I have recently learned that if you have a door in your house that constantly swings open on its own, take out the center hinge pin. Place the pin on a hard surface and hit the pin right in the middle with a hammer. It will bend the pin a little bit. Place the pin back in and the door should hold in position. If it still moves then do the top pin. I did it on 2 doors in my house and it works great. Of course if you put the doors in properly this shouldnt happen.
Millertyme is offline   Reply With Quote
Old 04-11-2011, 11:20 AM   #2
Rewards Points: 5,336
I hear a million hammers going as we speak.
Ron
Old 04-11-2011, 12:07 PM   #3
Old School
Willie T's Avatar
You know all that black grit that develops on some of your hinges? (Ask your wife.) Well, the bent hinge pin trick is what causes it. It's actually metal being ground off the inside of the hinges.
Willie T
JASCO Paint remover - what's the trick? cody21 Painting 7 11-19-2010 05:42 PM
Is this magic trick fake? Disbuzsf Off Topic 6 06-12-2010 11:51 PM
How to get nails out of basement floor. Is there some kind of trick? willowgirl Remodeling 5 03-03-2010 07:40 PM
trick a newby concocted fauer Plumbing 1 09-02-2008 10:26 PM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 06:22 AM
