Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-23-2011, 02:58 PM   #1
Door header ideas?
I'm looking for door header ideas.
I'd like to add a door header on to all my existing frames in the house.
Attached is a closeup of the casing I have now that I will replace the top with a door header. I also have attached a couple of samples that I have found.
Thanks!
noone is offline   Reply With Quote
Old 09-23-2011, 03:01 PM   #2
Door header ideas?
That will really add some elegance.
probably add a lot of appeal per dollar spent.
oldhouseguy is offline   Reply With Quote
Old 09-25-2011, 07:11 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Door header ideas?
for boston headers there are a couple options. you can buy boston header trim that is fairly simple all you need to do is cut them and put the mitre returns on the end. or you can be more creative and use flat stock in combination with several moldings to make your own custom header. i have done the latter many times with great success both on my own house and clients homes which i have put together custom trim packages
woodworkbykirk is offline   Reply With Quote
Old 09-25-2011, 07:53 PM   #4
Door header ideas?
Would you mind sharing pics?
Old 09-25-2011, 09:13 PM   #5
Door header ideas?
here you go, the teal color room header is a 1x6 with a bullnose on top and bottom with a chair rail molding under the top bullnose.
the purple grey room, is a 1x12 with chair rail on the bottom and a boston header molding up top
and the elevator door is a 1x6 with bullnose on the bottom, small crown on top with small casing directly under the crown
Door header ideas?-bos2.jpg   Door header ideas?-bos3.jpg   Door header ideas?-bostonhead1.jpg
Old 09-26-2011, 12:32 AM   #6
Door header ideas?
Thanks for the pics!
I think I like the teal room header the best, but I think I would like mine taller so maybe use a 1 x 8 instead?
Old 09-26-2011, 04:39 PM   #7
Door header ideas?
thats the whole idea of custom, you make it so its not something youll see in 50 other homes in your area. its something that drives me insane when trim subcontractors call themselves custom trim installers when they do teh exact same thing to every house they walk into , being every two weeks
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Garage shelving ideas koodawg General Discussion 3 12-31-2010 10:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General Discussion 5 05-24-2010 09:36 PM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
