Door Handle On A Gate - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 09:57 PM   #16
Rewards Points: 4,784
Originally Posted by Maintenance 6 View Post
I would go with a better quality entry lock because of the weather exposure (if that is an issue).
Yes, that's an issue and I was kind of worried about that. I didn't see any handles that were intended for weather exposure specifically.
Sometimes more expensive door handles, faucets, etc are simply more "designer" and not necessarily longer lasting. So I was planning on going with this one.
This one won't fly price-wise
http://www.homedepot.com/p/Schlage-O...1#.UVEBHzdWKZg
If I could find one of these locally I'd probably get it, what do you think?
http://www.homedepot.com/p/Arctek-2-...h#.UVD_mDdWKZg
http://www.homedepot.com/p/Schlage-G...3#.UVEAZjdWKZg
jeffnc is offline   Reply With Quote
Old 03-27-2013, 11:00 AM   #17
Mold!! Let's kill it!
Rewards Points: 2,012
I'd use the Schlage. You could put a light bead of sealant around the edge of the escutcheon to keep water from getting behind it. Otherwise the only thing you can do is keep everything lubricated well. $111.00 for a Schlage F51 lock is crazy. The other one for $37.73 is an F51 chassis too. The only difference is the Orbit 613 vs. Georgian 622, (knob design and the base finish). The mechanical parts are the same.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
hand drive (03-28-2013)
attaching redwood gate to block wall titan7 Concrete, Stone & Masonry 4 08-27-2012 12:53 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
