Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-15-2010, 12:01 PM   #1
Solutions (handyman)
Door frame material
I am restoring an old railway station and have to re-build a door and frame. The door is okay as we found one, however the frame was destroyed. It is an exterior door but the opening goes onto a covered platform so it is not directly hit by the elements. I was goung to make the frame out of spruce or pine, any down side to this type of wood? It will be painted and more for show than for function. We are in Canada where the weather varies but overall a dry climate.
thanks.
Mark Harvey is offline   Reply With Quote
Old 11-16-2010, 12:09 PM   #2
Door frame material
Properly maintained, it should be fine. Most wood door frames are these species.
Ron
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
Ceiling Ventilation Fan rjordan392 HVAC 1 05-20-2009 06:41 PM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 08:41 PM
