Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-16-2006, 03:13 PM   #1
Door Dilemma...
For reasons I won't go into...I have to install an interior door but can't mount it "on the inside edge" of the door jamb as is normally done. In other words, the door will almost be in the center of the jamb. What do the pros do if this rare? situation arises as far as the hinges go (the pin side)? I could router a slot for the hinge pin part of the hinge...or is there another way? I realize the door will only open 90 degrees when installed that way...and that is okay. Thanks!
sootybuttercup is offline   Reply With Quote
Old 12-16-2006, 07:37 PM   #2
General Contractor
joasis's Avatar
Door Dilemma...
Without going into a lot of detail, you sound like you have the general idea....there are few trisks to doing this, like making sure the mortises you cut for the hinges are true or plumb, stuff like that...just pay close attention to detail, and you will get it done.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
Old 12-16-2006, 08:48 PM   #3
Door Dilemma...
Thanks joasis...sounds good!
More On This Topic
So we’re working on our outside corner piece here. We’ve got our first piece done. It fits in just like that and you can see now why it is important to measure it from the back of your piece. We would have measured from the front of our piece... Read More »
So we’ve got our first piece cut. We’ve got the left edge flat still since it is going against this wall here this corner and we’ve got our other end with a 15 degree angle because it goes against this door jamb here and we want more of... Read More »
Learn how to paint refinished door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn how to caulk when refinishing door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn tools needed to refinish a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
