Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-06-2010, 04:53 PM   #1
Door closes by itself
Hello. I have a main entrance heavy duty door. I swing it open to reach the wall. If I leave the door alone, it will slowly close by itself.
I know I can put a box or a chair in front of it, but that is not the point.
The point is if I can do anything to the hinges so it remains open the way
it is supposed to. if I buy new hinges, it will solve the problem?
What can I do to the hinges? Thanks
Gabriel24 is offline   Reply With Quote
Old 11-06-2010, 05:29 PM   #2
the Musigician
DangerMouse's Avatar
You need to remove the casement and plumb the jamb. I'd shim it to true, then replace casement.
You can probably even leave the door on the hinges as you do this.
There may be more to it than that as you go, but that's basically it.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-06-2010, 05:44 PM   #3
jlhaslip's Avatar
bend one of the hinge pins
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following 3 Users Say Thank You to jlhaslip For This Useful Post:
BigJim (11-06-2010), Jay123 (11-06-2010), Thurman (11-07-2010)
Old 11-06-2010, 09:57 PM   #4
old guy contractor
tcleve4911's Avatar
It's a lot easier to bend the barrel than the pin.
I would bend Top & Bottom
tcleve4911 is offline   Reply With Quote
Old 11-06-2010, 10:00 PM   #5
STAFF
BigJim's Avatar
Lay the pin on a hard surface and hit it in the middle with a hammer, it will bend. Don't hit it hard though you don't want it to fly across the room.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
jlhaslip (11-06-2010)
