Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-05-2009, 02:22 PM   #1
jackie treehorn's Avatar
Default Door casing style help
I swear I can't make a decision if my life depended on it. I'm re-doing the casings and base moulding for my house, we have the standard 2 1/4" colonial which looks out of place in a house with an 18ft ceiling (in my opinion) Anyway, I'm more of a modern/contemporary type of person and cannot find any examples of what modern trim is supposed to look like so I started experimenting. I also searched the forum with no luck. I mainly don't want anything too ornate, but at the same time i don't want something that looks like it required no skill to put up.
I started to play around with a few different ideas, Help me decide
Keep in mind most of the trim is just barely hangin on so the reveals and everything might not be exact
Option #1 Bullnose top and bottom.
Option #2 Square stock top and bottom
Option #3 bullnose in middle ( I'm leaning more towards this one)
Option #4 simple capital up top
Thoughts??
jackie treehorn is offline   Reply With Quote
Old 10-05-2009, 03:02 PM   #2
Not so new
12penny's Avatar
jackie...dont take it personnally but I dont like any of them. Especially with a traditional 6 panel door.
I do like the bullnosed bottom one, maybe just a little thinner like 3/8, but on the top I'd rather see a simple crown like a bed molding.
12penny is offline   Reply With Quote
Old 10-05-2009, 03:51 PM   #3
I do want to swap out the doors eventually, probably to a two panel like so:
Old 10-05-2009, 04:09 PM   #4
Not so new
12penny's Avatar
Doesnt help. Still dont like any of them. Maybe someone else can narrow it down for you.
Old 10-05-2009, 08:29 PM   #5
Usually (I think usually) the door casing and the baseboards bear some stylistic relationship. What baseboard is being used?
bob22 is offline   Reply With Quote
Old 10-05-2009, 09:45 PM   #6
I'm doing something like this for the base, standard flat, with an 1/8 roundover:
I may router a groove down it later as well, dunno yet though
Old 10-05-2009, 09:56 PM   #7
Custom Cabinet Maker
dont know if you like the "old" style but you can go with sanitary casing, backband it, maybe use rosettes, then solid crown at the top. Use Plinth blocks with the base.
Somehow all the choices you have,appear like something is missing.
skymaster is offline   Reply With Quote
Old 10-05-2009, 10:15 PM   #8
Yeah, none of my choices have come across to me as "this is what I want", I may go through and tour some open houses to see what kinda styles I can gather.
Old 10-06-2009, 12:44 AM   #9
My two cents, I like the one in 12 penny's post.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 10-06-2009, 01:48 AM   #10
morningwood
A simple one that is used often up here and takes really no skill to put up is...not sure of the name, but it is not in any of the above pics.
Basically you dont have to do mitres with it. Each corner piece is actually a block with a design in it sometimes a circle or something. You run your trim up...run it across the frame...and join the two corners with the block design. very DIY and looks allright also.
You will find it in your hunting I assume. It comes cheap in MDF as well. Something to look at.
rahfiki is offline   Reply With Quote
Old 10-06-2009, 12:22 PM   #11
Ah, I think they're called rosettes, not my style, although at this point I can't even define my style. I'm not concerned with the difficulty in putting together something, I just don't want to put up something too plain or too ornate, probably a fine line there.
As for searching last night, I think the problem it the bullnose piece is too big, I found a picture of a setup that I like using the bullnose on top as the capital, and a smaller bullnose/bead on the bottom, pic here:
I also dug up a picture of one at a friends house that I liked:
Then I stumbled on this type of base moulding, makes me want to rethink what i was planning for base:
Old 10-06-2009, 12:28 PM   #12
Not so new
12penny's Avatar
I like the first one. And you're right, its a proportion thing.
Old 10-06-2009, 05:27 PM   #13
General Contractor
Capital is the term for the cap on a column. What you are referring to is called a pediment. I would go with the first one (post #11).
ARI001 is offline   Reply With Quote
Old 10-07-2009, 09:23 AM   #14
gravity always wins
Actually the small squares at the corners of a cased opening are called "plinth blocks". The circular design inside them is a rosette. A Pediment is triangular with a peak. Yes, the uppermost element of a column is a capital.
Old 10-07-2009, 10:14 AM   #15
General Contractor
I am aware of what a rosette and plinth blocks are and the applicable uses of both, however I was not referring to either in my post. Neither are any present in any of the pictures presented by the OP. A pediment is: An ornamental accent found above entry ways and windows. It is not necessarily triangular with a peak, however you are partially correct as in traditional architectural design that was a common application.
More On This Topic
Now we're ready to apply the pressure on the bubble. Secure it. Get it anchored back down to the substrate again. The way we do that is with the clamps and blocks. We've got several different kind of blocks we can use. We've got MDF, you can use part... Read More »
If you're one of those cooks or hosts who just has to be on the cutting edge, there's a kitchen gadget just for you. With the Swiss-made cheese and chocolate curler known as a Girolle, you can turn out beautifully shaped, tasty ruffled rosettes of cheese... Read More »
Hi, I'm Karen for Expert Village. Now, we're going to go back to the top...that tends to roll up on me a little bit...and we're going to crease it at the diagonal. So we're going to place our straight edge on this corner and on that corner of each... Read More »
Hi my name is Geoff Sterling and thank you for watching. This is an Expert Village "how to" video and this is how to practice Soo Bahk Do so in this episode right here what I am going to be showing you is all about the blocks. We are really known for our... Read More »
Hi I'm Betty Ingham and I'm speaking on behalf of Expert Village all of the woodwork had to be stripped it was painted many many colors and even a dental pick had to be used into the grooves that had been painted so many colors. My husband went ahead and... Read More »
Old style cutler hammer breakers xtremesurface Electrical 31 10-03-2009 11:42 AM
Shed Style or Truss? my5sons Building & Construction 26 09-14-2009 11:03 PM
Color options for a small cape style home Staticman2 General Discussion 2 06-20-2009 02:53 PM
Help me decide on cabinet style vetting Remodeling 3 01-07-2009 12:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
