Door Casing And Pneumatic Nailer - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 07:54 PM   #1
Door Casing and Pneumatic Nailer
I'm installing new casing around several doors. My question is, I have a Porter-Cable brad nailer and a finish nailer. Which should I be using to do the install? Also what size nails should I use? I was going to use the finish nailer with 16ga. 2" nails. I should have also mentioned that I have aluminum studs. Will that be a problem when I begin installing chair rail and crown?
joe3534 is offline   Reply With Quote
Old 12-12-2008, 08:42 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
The way i have installed the trim to metal studs is to clinch nail the casing. I run two row of construction caulking adhesive along top and bottom edges of chair rail or mouldings , then toe nail the chair rail up at a 45 degree angle and again above it at the top angled down at a 45 degree angle, thus clinching it to the wall. then wipe away the excess caulking that has pushed out with a wet sponge then shaped with a rag.
As for door casings it depends on how they framed the door openings, just metal ? or ripped 2x inserted into the stud cavities?. If its just metal I would chose to use the trim screws. as for the shock of the operation of the doors. if its wood filled I would go with the nails.
This has worked for me for years with good results, But what works for me might be diffrent from others. Good luck BOB.
Old 12-13-2008, 10:05 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As Bob stated, the key is to use construction adhesive and trim-head screws for installing molding onto steel studs.
Examples of trim head screws: http://www.rockler.com/product.cfm?page=1355
http://www.woodcraft.com/product.asp...&FamilyID=5241
http://www.grkfasteners.com/en/TRIM_0_information.htm
There are several methods to installing moldings over the steel framing. Here are some of the most common ones:
1.) Use only trim head screws.
2.) Use Trim heads and construction adhesive.
3.) Use Nails and construction adhesives. Then add screws where needed (while the construction adhesive is still elastic).
I prefer # 3, for expediancy.
When nailing, you alternate the direction of the nails: &
This gives the installation more holding power.
- Build Well -
Old 12-17-2008, 06:39 PM   #4
SNC
Use the glue and the trim screws.
SNC is offline   Reply With Quote
Paslode pneumatic finish nailer Ken101 Tools 9 10-23-2011 08:55 AM
Pneumatic Nailer MIKEGOUGH1 Tools 7 12-11-2006 08:20 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 11:24 AM
