-   -   door casing help!! (http://www.diychatroom.com/f14/door-casing-help-77120/)
baum 07-26-2010 07:35 AM
door casing help!!
So i was installing casing over the weekend. I would cut a 45 on both ends, but i am getting little gaps in the corners. How can i fix this?
Willie T 07-26-2010 07:37 AM
Sand the joints to fit.
baum 07-26-2010 07:44 AM
How hard is it to pull the casing off without breaking it?
what the easiest way of doing that?
JohnFRWhipple 07-26-2010 07:48 AM
Fixing the gaps in the casing.
Most likely your angle stop adjustment on your chop saw is out of wack a hair.
If the gap is tighter at the top or bottom this is usually the case. If the gap is even it is usually a sign that the jamb is slightly raised or proud of the finished drywall and a compound angle needs to be cut.
Can you show us some pictures.
I can suggest more precise info if I can see the problem...
baum 07-26-2010 07:50 AM
i will have to take pics, but its tighter at the bottom.
JohnFRWhipple 07-26-2010 08:28 AM
Check that your 45 and 45 angles make 90 with a proper square.
Try tapping a match book cover or two ply to the backside of your chop saws fence right near the middle - both sides.
Does this help?
Often the top corners on a door I will dry fit and then install the 3 boards as one with my biscuit cutter, biscuits and screws.
It is good to have a clean joint here. Take your time.
Is the stock seasoned?
