Door Casing Crown W/ Return???? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 12:53 PM   #1
Door casing crown w/ return????
Hi all, new here. I am trying to cut a piece of crown for my interior door casing top. I want it angled out (45 degree) and a return piece to the wall. I have a compound mitre saw and for the life of me cannot figure out the cuts. I have gone through a good bit of crown trying to figure this out. I have attached a photo of what I am wanting. (My piece of crown is flat on the back.)
usmc93 is offline   Reply With Quote
Old 03-03-2012, 01:40 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 384
You see how the crown is sitting there on the board, see if you can bed a short scrap piece of it into the bed of your miter saw just as it sits there in the picture. See how the crown sits at an angle in your saw? Now take that piece of crown and turn it over where the top is sitting on the base of the saw and the bottom of the crown is sitting on the back of the saw table bedded in.
Place the scrap piece on the left side of the saw blade, now turn the saw blade to 45degrees to your right, now make the cut. Take another scrap piece and bed it into the saw table like you did the first piece except you want the scrap piece to be on the right of the saw blade, turn the blade to the left 45 degrees and cut. Now place the two pieces together and see how they fit, there ya have it.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Tom Struble (03-03-2012)
Old 03-03-2012, 02:24 PM   #3
tried it...no luck. Probably reading your instructions wrong. I will keep trying. Running out of scrap crown in a hurry
Old 03-03-2012, 02:26 PM   #4
DIY staff
Rewards Points: 7,174
Look for a Youtube video --'cutting nested crown' should get you plenty of instructions--
On smaller crown cutting it angled against the fence is the way to do it --
Jiju1943 has given you a brief description of the technique.
Old 03-03-2012, 03:35 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
upside down and backwards
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
BigJim (03-03-2012)
Old 03-03-2012, 03:45 PM   #6
Thanks everyone...turns out you were all right of course, my problem is i didnt have it upside down. Got it rolling now just to put it together. Thanks
The Following 3 Users Say Thank You to usmc93 For This Useful Post:
BigJim (03-03-2012), oh'mike (03-03-2012), Tom Struble (03-03-2012)
Old 03-03-2012, 04:01 PM   #7
Rewards Points: 13,694
Make sure to use some Tite Bond II on the joint, not just tack it with nails.
Old 03-03-2012, 04:03 PM   #8
yea I was going to use bond, just trying to rig up a piece of wood for it to sit/mount to to the top of the existing board above the door. In case you cant tell I am a text book novice wood worker but take on stuff like i know what i am doing
Old 03-03-2012, 06:23 PM   #9
DIY staff
It's fun --you figured it out and now you have one more skill---all in all a good day!
Old 03-03-2012, 07:50 PM   #10
recently retired
Rewards Points: 280
That's rabbeted door crown which is flat on the top and back. Since you have a sliding chop saw this becomes easy. Take the crown, frieze & bead and glue it all together as a single piece using brad nails to hold until the glue sets. Take tape or use a pencil to mark the nail locations. Now cut the assembled entablature and make off the returns, all your miters are guaranteed to line up.
Keith Mathewson is offline   Reply With Quote
The Following 2 Users Say Thank You to Keith Mathewson For This Useful Post:
kj6887 (03-04-2012), Tom Struble (03-03-2012)
Old 03-03-2012, 08:13 PM   #11
also a good technique for post bases and caps
Door casing crown w/ return????-0715100903.jpg   Door casing crown w/ return????-0715100910.jpg   Door casing crown w/ return????-0715100920.jpg
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 02:39 PM
Looking for return noise help BlueNote HVAC 1 06-11-2011 10:06 PM
crown molding return momof2labs Carpentry 2 10-21-2010 08:04 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 09:40 PM
