Door Casing Advice - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 10:40 AM   #1
Rewards Points: 14
Door Casing Advice
My wife is tired of our tan plastic looking baseboard and door casing and has asked me to replace them with a squar look with an overhang.
I am attaching one pictures of our current set up and one picture of the casing look she is after.
Issue: Two of the doors are very close to each other. I have not measured it, but I think they are 1 inch away from the adjusent wall.
How would a trim carpentar approach this challange while keeping the look uniform with the rest of the doors?
Thanks All.
cweh is offline   Reply With Quote
Old 02-21-2014, 10:53 AM   #2
Rewards Points: 62
I would just use smaller trim than the last image. You can get anything from square to very elaborate carvings. The one below is a simple fluted design. I don't think running 1x into the corner would look very attractive. You could use rosettes in the top corners to give it a more finished look.
Zorfox is offline   Reply With Quote
Old 02-21-2014, 11:27 AM   #3
Rewards Points: 14
Zorfox - I agree, but she really wants the overhang look. I have not tried it but I was thinking of trying a 3/8 or 1/4 overhang.
The other problem that I think I'm going to face is, the casing. The casing is about 5/8ths and with the them so close they might acutally touch each other. grrrrrrrr
Trust me, once she has her mind set on something, its hard to change it.
Old 02-21-2014, 11:47 AM   #4
I have a similar problem with a couple of my doors in a hallway that leads to the garage. In my search, I've found a couple of images and the Joy of Moldings site that offered some pretty interesting ideas regarding "dissolves".
www.thejoyofmoldings.com
lohryx5 is offline   Reply With Quote
The Following User Says Thank You to lohryx5 For This Useful Post:
woodworkbykirk (02-21-2014)
Old 02-21-2014, 11:55 AM   #5
Jb1234's Avatar
Rewards Points: 87
I second how to do it above. That's how I did it in my house. Going for a Craftsman feel, I'd say you don't want it being thin and be afraid for it to touch. Run it into each other and "dissolve" it like above.
Jb1234 is offline   Reply With Quote
Old 02-21-2014, 12:47 PM   #6
Rewards Points: 14
Wow, dissolve looks nice. The only issue would be it does not have any overhang, which means to stay uniform, I have to skip the overhang look.
Old 02-21-2014, 02:09 PM   #7
You can have the trim meet in the middle and still do the overhang on the outside edges of the doors. Thing of the top board as spanning both doors as one unit.
Old 02-21-2014, 06:09 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,118
the dissolve method is pretty much the only way to do it properly, its a much cleaner more professional looking finish. i use it all the time when both windows and doors are close together at corners
the use of rosettes shown above is a very dated look. more specifically screams late 80's - early 90's
Door Casing Advice-60692_10151435823769466_590896664_n.jpg   Door Casing Advice-1394199_10152283804494466_1910286998_n.jpg
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
Jb1234 (02-21-2014), lohryx5 (02-21-2014)
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 09:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 06:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
