Does It Exist: A P2 Driver Bit That Leaves The Panhead 1/16 Or 1/8 Exposed? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 03:58 PM   #1
StoopidMonkey81's Avatar
Rewards Points: 82
Does it exist: A P2 driver bit that leaves the panhead 1/16 or 1/8 exposed?
Such a bit, similar to drywall bits that stop driving when the screw is just below surface level, would be very useful when hanging items with keyhole slots that want the screw's panhead exposed a prescribed amount. Does such a thing exist?
StoopidMonkey81 is offline   Reply With Quote
Old 12-19-2012, 04:07 PM   #2
Rewards Points: 2,212
HMMM never seen such a thing
mae-ling is offline   Reply With Quote
Old 12-19-2012, 04:32 PM   #3
Rewards Points: 14,312
Sure is, any big store should have one.
http://www.bing.com/images/search?q=...electedIndex=4
Old 12-19-2012, 05:14 PM   #4
Rewards Points: 82
Thanks for the suggestion, but something tells me that wouldn't allow for "negative depth" setting that would leave a screw head partially exposed. Those seem to be used for controlling how far -below- surface level a bit can go, not above.
Old 12-19-2012, 05:45 PM   #5
Not true.
Just using an impact driver I have enough control to set the screws any depth I want.
StoopidMonkey81 (12-20-2012)
Old 12-19-2012, 06:07 PM   #6
Rewards Points: 558
Use a drywall plug or any fasting system for drywall that requires a screw. Use a screwdriver to set the screw to the desired depth.
epson is offline   Reply With Quote
Old 12-20-2012, 06:57 AM   #7
I am sure a tool like that exists, probably real hard to find. I would just epoxy a spacer to the face of one of those drywall bits. I am assuming you have a project that requires many screws be set?
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
mae-ling (12-20-2012)
Old 12-20-2012, 04:43 PM   #8
Rewards Points: 82
Thanks Joe, I'll check into it! I -did- have a project that required a lot of hanging screws to be set but it's done now. I'm making a habit of asking myself, after I finish a project, what could I have had on hand to make this task easier? I've added quite a few goodies to my tool bag with that habit.
Old 12-20-2012, 07:13 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
you dont need a special bit for that. just use a cordless drill and adjust the torque on it so it stops driving the scew when it starts requing extra torque to set the screw
woodworkbykirk is offline   Reply With Quote
