Do I Need To Replace The Sill>> - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 11:06 AM   #1
Do I need to Replace the Sill>>
We own an older (1930s) lakeside camp in Maine. It sits atop piers. We are going to have a block foundation placed under one wall (to act as a foundation wall and to enclose an excavated crawl space). The 4 x 6 sill on that wall is fine ��� no rot, but it has been suggested that we replace it with a new pressure-treated (PT) sill. Is this necessary? How about simply placing a PT 2 x 6 under the sill (between the sill and the top of the concrete blocks)? Is that a viable option?
jarretr is offline   Reply With Quote
Old 08-01-2011, 05:00 PM   #2
Rewards Points: 5,336
That makes sense to me. You'll need to bolt through the old sill and new PT 2x6 to hold it down to the block wall.
These blocks should be filled with concrete to hold the anchor.
Ron
B. Franklin 1759
Tags
sill replacement
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 09:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
