Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-26-2009, 06:06 PM   #16
Ed
nice pic.
thanks
im going to bring that down to the inspections dept and get their buy-in.
im kicking myself now because i think i probably could have done that with just a rough octagon hole in the wall instead of taking out all the drywall....lesson learned i guess.
edfromma is offline   Reply With Quote
Old 10-26-2009, 10:21 PM   #17
Sister a stud next to the window for 2 total on one side, add 2 more right next to the window on the other side. Add sill (2x4) above and below window with 1/2" space around installed window. Support window on 1/4" lath continuous shim. Leave 1/4" gap above window/sill joint for settling later. (Required)
Install window per: http://www.finehomebuilding.com/how-...x?nterms=63740
http://www.lowes.com/lowes/lkn?actio...433&lpage=none
"lesson learned i guess. " ---- now you can comment the next time someone else with a similar post is undecided....... Join the group!
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-27-2009, 01:33 PM   #18
Old School
Willie T's Avatar
Didn't know you had removed all the drywall. You can build anything at all you choose with that much room. I thought you were working with just a window sized opening.
Willie T
Old 10-27-2009, 03:27 PM   #19
Ed
yeah. ive toyued with the dea of some bigger double hungs in that area instead of just the octagons and tehn adding some built-ins with benches etc. on a positive note, it gives me a chance to update the insulation on that wall -- whatever difference that makes.
More On This Topic
There is no reason to throw out a chair because of a loose chair rung. Fixing a loose chair rung is quick and easy to do. It is a great skill that allows you to fix flea market finds and garage sale cast-offs, or just to prolong the life of your existing... Read More »
Sometimes adult children are faced with the difficult realization that a parent is not able to keep up with his personal and financial affairs any longer. Becoming a guardian or conservator of your parent, however strange it seems, could be necessary in... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! I am Angela on behalf of expertvillage.com, and right now I am going to be taking about posture and the pains that can be induced from poor ergonomics and posture. Ergonomics is how your back is positioned and how your chair is structured. If it is... Read More »
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
Box/Bay window header Scuba_Dave Carpentry 6 08-26-2009 11:18 PM
Faulty header over 6' window chrissygarden Building & Construction 5 08-19-2009 01:05 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 06:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
