To put this in context (and so y'all will forgive my lack of woodwork knowledge) I am a housewife but would love to consider myself a handyman part time! I want to make a wood countertop for my kitchen island. I found a company that makes "DIY wood countertops" and I want to try my hand at it but I am concerned about the finishing/cutting process.:confused1:
I want to have a sink cut out and can use the jigsaw for that presumably but I have very little experience. I would also finish it with their recommended finish (waterlox tung oil).
Has anyone on here ever used the Craft Art DIY wood countertops? Are they really solid wood? Can you really do the finishing touches yourself without a wood shop? Here is a link to their DIY stuff.
I have bought butcher block tops from L.L. Johnson in Michigan and from Owl Hardwood in Illinois and cut sanded and finished them ---It's wood---they are not difficult to do unless you have a mitered corner.
You will need a jigsaw for the sink cut out --I would use a Circular saw and use the jigsaw for the corners because its faster,but you could do the entire cut with a jig saw.
A tip---make the four long cuts leaving a bit uncut in each corner ---(to support the cut out) then nip out the four corners.
A random orbit sander (or an old pad sander) will make fast work of smoothing out the surface.
Ron6519 - I did some extensive research because A. that was hilarious and B. I probably shouldn't buy from a company like that... but as yet, no successful results on my google searches about prostitutes/slaves/do-it-yourself wood countertops. I will keep that in mind though.. Oh, and C. Now my work laptop has prostitution searches on it that probably will be difficult to explain. woops.:whistling2:
oh'mike - Thanks for the tips on the cut out and sanding. I will definitely do that. I am not doing a miter joint, thank god. I won't have a joint at all because they have a size that works perfectly. (they have a bunch of standard sizes you can pick from).
You sound like you know your stuff - Ron feel free to jump in too : ) - how do you feel about using a tack cloth after sanding and before oiling? The company I am buying from recommends using one. I have heard mixed reviews on that. Someone told me that it can affect the finish because of the resin on the tack cloth. Did you experience that problem?
"-It's wood-" That was insanely helpful / insanely simple advice. Love it.
Thanks, Mike. I will follow up and post pics of my project so you can see how much you helped!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
