DIY Wall Divider Using Tension Post And Door Panel - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 02:42 AM   #1
DIY Wall Divider Using Tension Post and Door Panel
Looking for advice on how to create a DIY wall divider using:
- IKEA PAX SEKKEN DOOR, Pair of sliding door frames; Tempered/safety glass, Glass enamel
- Tension Post
s that are Height adjustable from 82 5/8-129 7/8", which allows you to utilize the entire ceiling height.
- Mounting Fixtures
Does anyone have an idea of how I could affix the door panel to the tension posts -- one post on each side of the door? It would end up looking like this:
http://www.apartmenttherapy.com/tran...er-syste-93481
ENNYC is offline   Reply With Quote
Old 04-25-2013, 09:27 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
Those doors slide horizontally and the rods you listed are intended to be installed vertically right. Am I to assume that you dont want the doors to slide once they are installed?
brockmiera is offline   Reply With Quote
Old 04-26-2013, 01:54 AM   #3
Yes. You're spot on. The doors will be used as panels -- no sliding function -- just to separate the space and act as a room divider. Is this possible?
Old 04-26-2013, 09:18 AM   #4
brockmiera's Avatar
Its definitely possible. You are going to have to make sure that your tension rods are centered on a ceiling joist or you will have to install blocking between the joists (if you have access above this will be very easy) As far as a bracket is concerned I'm thinking something like a chain link fence post tension band.
You could drill a hole in the door and then use a galvanized bolt or maybe even a threaded hook to hang towels or a robe or whatever on the bedroom side of the door.
