DIY Mantel Need Sugestions(pics) - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 12:47 PM   #1
DIY mantel need sugestions(pics)
I want to build a mantel shelf or surround here, i think the 3" on each side of the brick may not be enough for a surround. Any suggestions or ideas. I'd like to do something just not sure what this is what i had in mind
zephead is offline   Reply With Quote
Old 01-31-2013, 01:00 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
Ok, so that curved top is annoying me......lol
You can build a mantle just like the one in the pic below and wrap is around to the wall, or you can do built ins on either side and incorporate the mantle.
You can for a modern type look and put limestone everywhere.
Go rustic and put in large stone.
Good luck. Would love to see how it turns out.
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 01-31-2013, 01:05 PM   #3
ya the curves annoy me too, the thing is its an old home with plaster walls and it would be a real pain to rip em out. i think i like the wrap around look as like the pic above. I guess i just wasnt sure if the smaller dimensional size of my fireplace would look good with a wrap around. also i will update with pics when finished.
Old 01-31-2013, 04:13 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A long time ago, when we first bought our house and I was talking to my sister about what I wanted to change, she said something I'll always remember. She said "Respect the house."
What that means is a ornate Victorian surround will look strange in a southwestern adobe home.
What style home do you have? I would try to stay with something appropriate to the style.
Old 01-31-2013, 04:29 PM   #5
well the home is in Chicago. Its a typical Chicago bungalow. The decor in this room will lean more towards eastcoast cape codish, we will be wainscoting the walls.
Old 01-31-2013, 04:46 PM   #6
Rewards Points: 13,296
Smeone should be shot for painting that brick like that.
Old 01-31-2013, 05:53 PM   #7
Totally agree joe, when we bought the home that awful yellow was painted in every room.
Old 01-31-2013, 06:07 PM   #8
What is that at the bottom of the wall there trying to use for a baseboard?
Old 01-31-2013, 06:13 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
This is how we solved our problem.....and I bet our fireplace was uglier than yours....
before...
after....
Unless you can get rid of the arched brick around the opening....I think your options are limited....
ddawg16 is online now   Reply With Quote
Old 01-31-2013, 06:21 PM   #10
Joe, the bottom of the wall is discolored because the baseboard was installed before the nasty yellow paint. D solid work man, that arch looks real slick with the new surround. I think Im going to build something as close to my initial reference picture
Old 01-31-2013, 08:38 PM   #11
DIY staff
Rewards Points: 7,174
Just a suggestion to help with proportion----
Build a mock up using Styrofoam sheet goods---
Often what you think will look good--looks better after some adjusting--
I had to build and change my mock ups three times on the last fireplace surround I built--It took a few tries.
ddawg16 (02-01-2013)
Old 01-31-2013, 08:51 PM   #12
Mike, that's a really good idea. The main issue I've been having is not being able to visualize if a full surround would look appropriate with a smaller fire place. Thanks
Old 01-31-2013, 09:28 PM   #13
DIY staff
Blue tape and styrofoam is better than wishing for something different----
Also start collecting pictures of styles that you like----
I once built a full bar and back bar from a snap shot of an antique side board that the customer liked---
Old 02-01-2013, 07:15 AM   #14
Rewards Points: 1,294
It looks to me like the baseboard is gone and the bare plaster is showing
danpik is offline   Reply With Quote
Old 02-01-2013, 09:41 AM   #15
Rewards Points: 150
As long as its non combustible u can always pack it out and go straight just go from the ends and it will be covered in middle ( like a piece of cement board
kaschmid3 is offline   Reply With Quote
Fireplace Mantel Move PhishPhix Concrete, Stone & Masonry 2 11-08-2012 07:59 PM
Building a fireplace mantel shelf NewHomeDIYGuy Carpentry 2 08-20-2012 04:22 PM
Repainting fireplace mantel (HVLP vs Airless) titan7 Painting 5 06-18-2012 09:52 PM
Exposed wood mantel operagost Safety 7 01-15-2010 08:05 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
