Diy Fitness Pole... - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 06:34 PM   #1
diy fitness pole...
hey everybody im working on a small project at home its a fitness/strip pole for my living room. I got the pole down pack but i've just notice that my ceiling is on a slant??? this has poked a big hole in my progress and after moving the pole to 10 different locations i give up...
is there something i can do to even a part of the ceiling out
or put between the dome of the pole and the ceiling or
mount on the ceiling to make it level?
see part of the dome of the pole is about 3-4 inches and the other part is 1-2 inches
what should i do? someone please help i really want to test out my skills/fitness...
cheers
cakes is offline   Reply With Quote
Old 04-09-2013, 06:40 PM   #2
Rewards Points: 744
Once this is complete, please post back with some video demonstrating how well it works.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
r0ckstarr (04-10-2013)
Old 04-09-2013, 06:59 PM   #3
Rewards Points: 13,300
Hope your good at sheetrock repairs.
Without being able to get in behind the sheetrock to add a backer to attach this to is going to fail.
Got a picture of this pole?
Just when you thought you heard it all.
Old 04-09-2013, 07:22 PM   #4
Rewards Points: 744
Unless it's designed to attach to a ceiling joist. A picture of the pole and its mount would help.
By chance is this post related to this one? Mirrored Roof/ceiling
creeper (04-09-2013)
Old 04-09-2013, 07:46 PM   #5
hey thanks for all the quick replies guys
im fimilar with sheetrock i dont know if i could unless i had really clear instructions but i'll try anything at this point
no im not fat lol (122lbs.)
and i attached a couple of pics hope this helps...
1st pic is the whole pole
2nd pic top of the pole(dome)
3rd pic bottom the pole(base)
rest of the pics are the dome up close with and w/o cover
diy fitness pole...-2013-04-10-09.27.18.jpg   diy fitness pole...-2013-04-10-09.26.51.jpg   diy fitness pole...-2013-04-10-09.27.00.jpg   diy fitness pole...-2013-04-10-09.39.06.jpg   diy fitness pole...-2013-04-10-09.39.37.jpg
Old 04-09-2013, 07:54 PM   #6
i dont plan on keeping it there i just put it there for the moment
helpful tips plz
Old 04-09-2013, 07:56 PM   #7
not related to the mirror post although it sounds like a cool idea.... but no pole first lol
cheers
Old 04-09-2013, 09:01 PM   #8
funfool's Avatar
Rewards Points: 534
It is obvious, you will need a professional handyman for the project.
Is very important that the top of the post is anchored for safety.
Is also a angled ceiling so it is not difficult, but again, someone that knows what they are doing.
Again you say is not the exact position for the pole.
May have to try it in a few locations to actually get it installed properly where you want it.
If only I was a handyman in Australia
funfool is offline   Reply With Quote
Old 04-09-2013, 09:57 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
it either needs to be anchored to a joist or you need to open up the ceiling and install cross blocking on its flat between the joists
woodworkbykirk is offline   Reply With Quote
Old 04-09-2013, 11:33 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
That thing better be tied into structure and it probably isn't a bad idea to pull down some drywall and install blockers to tie the joist together a bit better.
Old 04-10-2013, 01:51 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
Here is a good example of what happens if the pole is not properly attached. In fact, your pole looks exactly like the one in this video.
Old 04-10-2013, 04:25 AM   #12
Its okay to laugh at it when it is an advertisement.
Old 04-10-2013, 07:41 AM   #13
r0ckstarr's Avatar
Rewards Points: 1,998
How much of a slant does your ceiling have? When you say "slant", I think of this:
Do you have a picture showing where you would like to mount the pole?
r0ckstarr is online now   Reply With Quote
Old 04-10-2013, 05:25 PM   #14
okay heres a pic of the ceiling on what i call a slant
and one of me ...I'M NOT FAT lol
im after do-able ideas guys please is there something i can put between the ceiling and dome or attach to the ceiling or ?
i dont want to knock my ceiling down i really dont
cheers
diy fitness pole...-2013-04-11-07.10.48.jpg   diy fitness pole...-snapshot_20130411_5.jpg
Old 04-10-2013, 05:40 PM   #15
JOATMON
ddawg16's Avatar
The problem you have is that the pole depends on friction to hold the top....on a drywalled ceiling...not a whole lot of friction. Additionally, as you crank up the cup against the ceiling, it pushes it up and most likely deforms the ceiling a little.
I think the only thing your going to be able to do is make a round disk about 3/4" thick that would fit just inside the upper cone.
You then screw this to your ceiling centered on a ceiling joist.
Then when you want to use the pole...put it up with the upper cone covering the disk. The disk should prevent the top from moving.
The Following User Says Thank You to ddawg16 For This Useful Post:
r0ckstarr (04-11-2013)
Tags
dance , fitness , pole , strip
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Replacing Load Bearing Wall with Pole whitediamond642 Building & Construction 5 06-22-2012 12:57 PM
Can a T104 dual pole timer be used as a single pole installation? illuminate Electrical 6 06-13-2012 06:33 PM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 01:37 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
