Diagonal Deck Boards - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 08:41 AM   #1
I have an existing deck with joists (2x8's) 16" O.C.
I want to replace my deck boards (5/4 x 6's) and lay them diagonal.
I have heard a lot about needing the joists 12" O.C.
Any advice out there?
Ryan
csiryan is offline   Reply With Quote
Old 05-01-2010, 08:45 AM   #2
will be springy better to use 2x on diagonal
The older I get the better I was
Old 05-01-2010, 07:31 PM   #3
remodeling pro
5/4 is going to be springy with 16"OC for the framing; because the decking is essentialy now almost 17 inches between supports, as compared to 14 1/2" for the perpendicular run. Besides the extra springyness, the boards tend to create humps and dips betwen the joists when the water/sun starts to work on them.
It is done, but I would suggest temorarily laying a few boards and seeing how they feel to you when you walk on them. You are not going to break the board with normal residential usage, just the "feeling" may be a bit bouncy for you.
troubleseeker is offline   Reply With Quote
Old 05-01-2010, 11:02 PM   #4
Registered User
Rewards Points: 4,894
With 17" diagonal at 12" on center, it stretches to 22-5/8" at 16" on center........
Be safe, Gary
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 12:09 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
diagonal deck boards boots Carpentry 1 03-09-2007 09:15 PM
Cedar Deck boards Outbacker Painting 2 03-04-2006 02:12 PM
