I understand pretty well about vapor barriers and moisture management but did not install any insulation under my bottom plate. I decided against foam board for a number of reasons so moisture management for the basement remodel is being completed through the use of 6 mil sheeting sealed to the top plate and base of the wall (and eventually on top of the slab under what will be my floor) with acoustic sealant. I insulated and sealed all the inter-joice spaces with 1" thick rigid insulation and foam (sealing and insulating the sill plate).
Not so sure that backer rod will give me the decoupling that I am after. Someone suggested to me that I screw the top plate into the sill plate. I would think that the mass of the sill plate (its a 6 x 6 with an entire house sitting on it) would dampen any vibrations pretty well. The other suggestion was attaching the 2x4's to the concrete foundation (poured not block) with brackets (although this would be a great deal more drilling or pheumatic nailing into concrete
I have been googeling "floating walls" as this seems to be the correct terminology no?
