-   -   Decking wood vs framing wood (http://www.diychatroom.com/f14/decking-wood-vs-framing-wood-171404/)
miamicuse 02-08-2013 06:34 PM
I need some boards that's thicker than 1x for bracing. I found this decking wood that's 5/4" thick at Home Depot.
http://www.homedepot.com/Lumber-Composites-Decking-Decking-Boards-and-Posts/h_d1/N-5yc1vZbqm4/R-100087342/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051#.URWKJPL_3s0
5/4 x 6 x 8 Premium Pressure-Treated Decking
What I found interesting is these boards are MUCH harder then the standard framing 1Xs and 2Xs which I believe are made of pine. Those my drills and drivers would cut through like knife through butter. This wood decking my drill would take over a minute to drill through with new wood bits. Old bits wouldn't even make a dent. What kind of wood is this?
Furthermore, I understand one needs to use pressure treated wood furrings when connecting to concrete block walls. However, if the wall is not perfectly plumb and need to be shimmed a little, why are those shims never pressure treated? Doesn't that defeats the purpose?
framer52 02-08-2013 06:43 PM
southern yellow pine
always use cedar shingles and hey have properties that resist moisture in them
woodworkbykirk 02-08-2013 07:20 PM
you can get non pressure treated 5/4 stock no problem at a lumber yard, just dont go to a big box.. as for keeping wood out of contact of concrete just use either 8 mil vapor barrier or sil gasket.. regarding the shims.. cedar will still rot if its against a concrete wall that has moisture issues. you can also buy plastic shims at big box stores though you only get 1/5 the amount you would from a bundle of cedar shims at the same cost
kwikfishron 02-08-2013 09:11 PM
Change the drill rotation from reverse to forward and try again. :wink:
miamicuse 02-08-2013 09:41 PM
No serious. It was in forward. I couldn't believe it. I had to lean in real hard too.
woodworkbykirk 02-09-2013 08:32 AM
buy a new bit
A Squared 02-09-2013 12:31 PM
So what are you doing that 4/4 is inadequate but 5/4 is sufficient, and how did you determine that?
If you're seriously taking more than a minute to drill 5/4 of any kind of wood, you're doing something wrong.
woodworkbykirk 02-09-2013 02:29 PM
needing 5/4 is commonly needed in renos in order to several things.. such as furring out walls.. strapping ceilings where existing pipes are just over 3/4" thick so that extra 1/4 is needed so drywall will clear it when hung.. amoung other things
