Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-18-2012, 02:10 PM   #1
Question
decking screws
I am building a new deck and have a couple questions. Using 5-1/4 X 6 pt decking boards. What length of screws should be used and how many screws to the board?
tgsnj is offline   Reply With Quote
Old 09-18-2012, 02:20 PM   #2
decking screws
5-1/4 thick
Going to need 7" lag bolts.
Only kidding, 2-1/2 ceramic coated decking screws will work fine.
2, screws per board in each joist.
If there was only one there going to curl more then they already will.
If you use an impact driver it will work far better then a drill.
Old 09-18-2012, 09:47 PM   #3
AHH, SPANS!!!
decking screws
2 screws per joist intersection,screws need to be located about 1" in from the deck board edges. If the decking lumber is really wet with treatment a construction adhesive glue placed between joist and decking board during installation may help slow down initial shrinkage of the lumber.
hand drive is offline   Reply With Quote
Old 09-19-2012, 08:52 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
decking screws
i agree with the 2 1/1" coated screws and to have 2 per joist on every board 1" in from the edge.. but using construction adhesive to slow shrinking??????????? that wont do anything.. the shrinking is caused by the wood drying out..
the only thing i would advise is to make sure you snap some control lines to use for keeping the boards straight, also use a common nail or the blade of a speed square to use as a spacer for the boards. though some slam the boards tight together as when the boards dry out they will shrink creating a small gap for drainage
woodworkbykirk is offline   Reply With Quote
Old 09-30-2012, 11:10 PM   #5
Davejss's Avatar
decking screws
Don't bother with a spacer. P.T. Decking will shrink more than enough to leave a proper gap. I'm not a screw fan. I prefer 8d galvy ring gun nails. Much, much quicker than screws and they hold just fine. I've been building P.T. decks like this forever and I've never had an issue.
Davejss is offline   Reply With Quote
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 09:19 PM
Switch & receptacle cover screws? rjniles Electrical 8 09-28-2011 03:59 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 03:08 AM
What's the trick to get drywall screws all the way in? cody21 Drywall & Plaster 14 08-10-2009 12:05 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
