Deck Swaying Too Much...help Needed - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 01:58 PM   #31
You must be the personality type not the looks type best of luck
dvatt is offline   Reply With Quote
Old 08-13-2011, 02:06 PM   #32
Framing Contractor
Brilliant response! When you build your first deck...let us know how it goes.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
concretemasonry (08-13-2011), oh'mike (08-13-2011)
Old 08-13-2011, 10:17 PM   #33
joes way will work the best after all its underneath the deck unless theres going to be people who are going to party underneath then what does it matter what the heck it looks like , i like how you guys seek advice and then when you get it it doesnt seem good enough
fulton 22175 is offline   Reply With Quote
Old 08-13-2011, 10:38 PM   #34
Rewards Points: 5,336
Originally Posted by mkb63 View Post
Thanks for all of the posts about the deck cross bracing. This deck luckily has the ledger board attached to the house for lateral stability at one end.
I have a similar but what seems like a more complicated problem.
I built a completely freestanding elevated platform (9ft up)for my kids playset (12x18) to be built off of. It rests on (6) 6x6 posts sitting on 10" diameter concrete piers, with doubled up 2x10s acting as beams between each pair of posts.
After assembling the posts, beams and joists the platform had a serious sway on top, despite being very stable vertically. I added several diaganol braces from the joists to the beams and posts. This helped with some of the swaying, especially parallel to the beams. The swaying perpendicular to the beams was much worse.
I am considering diagnol bracing from the beam to the base of the posts OR heavy gauge cable bolted to each side with a tensioning turnbuckle on each cable.
Any thoughts on the two bracing methods??? or how to attach them most securely to the beam and posts?
Please note that I intend to hand a climbing wall, swings, a slide and other playset items off of this platform.
Thanks for your insight!
The bracing needs to be rigid on both sides of the post. I know you want to minimize the visual under the deck, but I don't think you can avoid the 2x4 bracing.
Ron
B. Franklin 1759
Old 08-13-2011, 10:42 PM   #35
Can we put some punctuation in there somewhere, anywhere?
There are commas and periods out of work.
Ron
B. Franklin 1759
Old 09-02-2011, 06:36 PM   #36
Bump.
I plan on installing the sway bracing this weekend and wanted to follow up with a couple questions.
Do you think I could make upside down Vs between the posts (top to bottom) instead of using 1 diagonal between the posts? The upside down Vs would still allow easier access to t.e underside of the deck. Or is the roughly 45 degree angle with the one diagonal make a bigger difference?
ALso, tonight I clamped a couple 2x4s between 2 of the posts and shook the deck...couldn't discern any noticeable difference in the amount of sway. I'm sure part of this is because the bracing was only clamped and not nailed. Is it worth it to try to nail these shorter pieces at every post or will I ultimately be disappointed? I'm more concerned with safety than appearance and functionality but would like the best of both worlds if possible. Who wouldnt?
Thanks again for all the advice!
Seven333 is offline   Reply With Quote
Old 09-02-2011, 08:46 PM   #37
Missouri Bound's Avatar
If you want to brace the deck but not see the bracing, you could attach 5/4 to the bottom of the deck diagonally. Serves the same purpose as installing the deck at a diagonal and is nearly invisible.
Old 09-03-2011, 11:01 AM   #38
But wait I suggested that and got told I don't know anything!!!!
Old 09-03-2011, 07:02 PM   #39
Yes you did. I didn't steal it, I just missed it. Maybe your sarcasm had something to do with the criticism.
Old 09-06-2011, 09:49 AM   #40
Where I live (earthquake country), none of these suggestions would pass inspection by themselves. Way more bracing required.
A poor pic representing the bracing, but you get the idea.
redwood is offline   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Leveling a deck denemante Building & Construction 10 08-24-2010 08:11 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
