Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-27-2004, 11:07 AM   #1
Deck to support spa
Building a new deck out of PT and want to incorporate a sunken spa. Figuring I'll need at least 100 psf, can someone please give me an idea of how to build the supporting platform for the spa (6x6). The bottom of the spa will be no more than 3 ft off ground. Thanks.
handiandi is offline   Reply With Quote
Old 08-29-2004, 12:57 PM   #2
Contractor
Deck to support spa
handi, I arrive at a figure of about 225 psf.
4500 lbs water, 300 lbs spa, 4 people @ 150lbs X min. safety factor of 3 = 16,180 lbs total weight and we go back to the post/slab/block construction that you don't like to hear about. In this instance you could cap with 2" PT lumber as heat isn't a factor.
Teetorbilt is offline   Reply With Quote
Old 02-08-2005, 05:41 PM   #3
Carpenter
DecksEtc's Avatar
Deck to support spa
I wouldn't recommend anything less than a slab. The amount of wood you would have to use to support the spa would likely cost you more than the slab. The slab won't collapse, the deck probably will.
DecksEtc is offline   Reply With Quote
Old 07-03-2005, 03:19 PM   #4
Deck to support spa
I agree with this because I saw it first hand. The deck was only 5ft off the ground so they dropped a spa in with extra wooden supports. During the night (after 2 years) the whole deck came down with the spa. What a nightmare. Spa was ruined, deck was ruined, it pulled a beam out of the stucco which tore from the back of the house. Probably cost the homeowner $20k to fix that mess. Always go with the safe route - if that guy was in the spa, he wouldn't be here today.
meiersenterprises is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
How to make existing deck support more weight? tigerbalm2424 Building & Construction 7 04-22-2007 01:12 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
