-   -   Deck Stairs issue...... (http://www.diychatroom.com/f14/deck-stairs-issue-182901/)
ryan5068 07-02-2013 01:51 AM
So I am in the process of building my stairs on my deck and I am using Choicedek from Lowes. I like the stuff for the deck boards but the ends of the stairs have like 3 waves on the bottom of the boards. Now if I run the stair tread planks off the edges of the stringers/treads like you normally would do it will look awful in my opinion because from a side view of the stairs you would see the 3 humps on the bottom of the choicedek.
I am thinking I will cut the boards so they are flush with the edges of the stair treads and then install actual trim boards flush up against the composite planks. I will then take the trim boards back to the actual deck running horizontal so it will be a boxed in set of stairs. I am not sure I can do much more.
Anyone have any other suggestions or am I on the right track?
joecaption 07-02-2013 04:44 AM
Another way to cover up the stringers and the treads is to use the composite fascia board that's really made to cover up the rim joist.
I set the stringer on it to act as a template and cut the two ends. Once the treads are in place I trace and cut the top part, use a round over bit and a sander to finish it before installing.
