Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-07-2006, 10:41 PM   #1
Deck stairs
Three-tread stringers coming down to asphalt driveway which slopes from right to left as well as being bumpy. I can make each stringer a different height ,at the bottom,but what happens when the asphalt changes its shape,again,in the future ? I thought about putting down a piece of PT planking for the stringers to rest on. That way they would all be the same size and shape and they could be shimmed,if necessary,at a later date. Anybody have any suggestions ?
gmjosey is offline   Reply With Quote
Old 06-08-2006, 07:34 AM   #2
Deck stairs
Form and pour a level concrete pad upon which the stringers can land so they can all be equal lengths. Building codes require it.
This pad should have an area at least 3'x3' upon which to step at the bottom.
manhattan42 is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
