Are Deck Screws Enough To Stop A Kick In? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 10:10 PM   #16
Using the drill bit shank screw "between the inside diameter of the screw theads hte same, if thats still tight 1 / 64 size, and even some liquid soap detergent on the screws, Wedding Cufflinks the screws into the lubrication it makes it easier.
yingxuy is offline   Reply With Quote
Old 11-30-2011, 10:44 AM   #17
Crusty Old Dude
Big Stud's Avatar
I have to agree with orangeclawhammer, locks only keep honest people honest. They might slow a thief down but may not deter them. I have yet to see a door that could not be broken into by some means.
Big Stud is offline   Reply With Quote
Old 12-10-2011, 12:32 PM   #18
I find that a clearly marked GLOCK sticker at eye level helps with break ins . I don't bother locking the doors most of the time, they are there just to keep out the misquitos. theifs will get in if they want. you could install a vault door that looks like a regular door from the out side.
woodmeistro is offline   Reply With Quote
Old 12-10-2011, 09:19 PM   #19
Originally Posted by Tonglebeak View Post
I bought a $60 lockset from HD. The "kwikset signature series" came with a door knob and deadbolt, with a Grade 1 label.
Haven't seen this entry set, but $60 is pretty cheap. Not to mention the quality of stuff from the big box stores. If the lock is the weakest point in your entry, go to a real lockset company
mrgins is offline   Reply With Quote
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 07:32 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 01:53 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
